Hi all, Having approached recently to Arduino, I started doing some tests with various relay LED buttons sensors etc. etc. all operations that I were quite simple.
Now I wanted to interface to my Arduino Mega can send and receive X10 commands, I implemented the library entered parts of code necessary to its use but still I received to fill the following error:
'PowerLineEvent' was not declared in this scope
powerLineEvent is the event that is generated when an X10 message arrives
obviously firmly inscribed within the code.
I am thinking it was wrong I made a sketch of example by the network (by copying exactly) there also experiencing the same error
by trying to bring him to the bone
I have written:
#include <X10ex.h>
X10ex x10ex = X10ex(2, 4, 5, 6, true, powerLineEvent, 1, 50);
void powerLineEvent(char house, byte unit, byte command, byte extData, byte extCommand, byte remainingBits)
the error persists :o
I must conclude that it should declare void in some way but there is nothing in the documentation about.
Also if I tried all networked projects that use that library they would return the same error (I have tried 3) so why the others go?
If anyone has had experience with this ... thanks a lot from now on.
P.S. the latest example I downloaded here: x10/X10_Simple.ino at ccb6aa691eb652c1e9f2d8c3a8e5333d7147a57a · tmittet/x10 · GitHub
or here:
libraries here (with another example)
https://code.google.com/archive/p/arduino-x10/downloads
thank you all
