Hi guys
I control a mg946r servo and various mg996r with serial monitor (or this is my idea xd), and this code with de 996r works it, but with 996r doesnt.
#include <Servo.h>
Servo servoMotor;
int input;
servoMotor.attach(9);
servoMotor.write(input);
Serial.println("Enter an Angle:");
if (Serial.available() > 0) {
input = Serial.parseInt();
if (input > 180 || input < 0) {
Serial.println ("This isn't valid! Try again!");
else {
Serial.println(String("You entered: ") + input + String("!"));
delay (1000);
The mg946r makes two moves at once (i dont want this) and close serial. After to download java 1.8.0_341 the console said this:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at processing.app.Serial.write(Serial.java:254)
at processing.app.Serial.write(Serial.java:274)
at processing.app.SerialMonitor.send(SerialMonitor.java:122)
at processing.app.SerialMonitor.lambda$new$1(SerialMonitor.java:66)
at javax.swing.JTextField.fireActionPerformed(JTextField.java:508)
at javax.swing.JTextField.postActionEvent(JTextField.java:721)
at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:836)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1668)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2882)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2929)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2845)
at java.awt.Component.processEvent(Component.java:6316)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:835)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1103)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:974)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:800)
at java.awt.Component.dispatchEventImpl(Component.java:4760)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
