Hello.
I have some problems with my motor setup. I've got a motor connected to a L293D motor drive rwith an arduino board. The program works as it should, but the motor is going too slow. I tried to mesure the voltage, which said the motor supply was 3,2 volts. I have connected +5 volts to both pin 8 and 16 on the motor controller. I was hoping that my motor would get 5 volts, but apperently it doesn't.
Here is a link for the L293D and setup: http://luckylarry.co.uk/arduino-projects/control-a-dc-motor-with-arduino-and-l293d-chip/
The L293 uses Darlington output stages, so it will drop about 2V internally. For a low voltage supply it's a poor design because high loses are unavoidable. MOSFET H-bridge chips will do much better.
I've now tried to boost up the supply for the motors to 6,2 volt, but the voltage for the motors is still the same (3,2 V). Should I buy another H-bridge, or is it anything I can do?
The example doesn't use PWM, just switching direction. It ought to be getting more voltage to the motor if there's more voltage at the supply.
If the power supply isn't up to the task though the motor may be overloading it - have you measured the supply voltage when the motor is running?
Also I note that the example circuit has poor decoupling - the 220nF ceramic capacitor they describe as "optional" is required for reliable operation as with any logic circuitry. The electrolytic decoupling of 10uF is rather small, I would prefer 1000uF or similar
Yes, i tried to measure the voltage when the motor was running, but no good luck. Do you think i need to buy another kind of H-bridge, or should it work proporly with the one I got?
Well it seems like when I measure the voltage with the motor connected, i only get 3,2 volts, but if I remove them i get 4,5 volt( which is the voltage from the battery).
I measure the voltage from the battery without the motor attached:
Then I get 4,3 volts from a 4,5 volt battery, which is okey. And I get 4,4 volts from the pins from the l293d which is supposed to go to the motors.
Then i measured the voltage with the motor:
Then I also got 4,3 volt from the battery, but only 2,5 volts from the motor pins on the l293d.
I'm simply trying to figure out why that is happening - the loss of 2 volts is a given with Darlington outputs, I was trying to figure out why this had increased to 3V loss - though this could simply be more resistive losses with higher current.
The L293 is never going to be efficient at low voltages with Darlington outputs. Its still going to be no better that 80% or so at 12V which is rather lame.
