Hello everyone. As a school project I was tasked with creating a 2WD car powered by arduino and will use a controlling software on pc that connects them together using bluetooth (Specifically the HC-06 module). The tests were going great I was making sure the motors, software, connection were working properly but now when I try to move my car any other direction excluding straight my program crashes. This may be a result of poor programming on the Python side but I still wanted to ask here as I might have made some mistakes in the Arduino side aswell. I'm providing codes for both of them below:
#include <SoftwareSerial.h>
#include <QMC5883LCompass.h>
// For Modules
const int bluetoothRX = 7;
const int bluetoothTX = 6;
const int trigger = 5;
const int buzzer = 2;
const int echo = 4;
// For Motor A
const int MotorPinA = 12;
const int MotorSpeedPinA = 3;
const int MotorBrakePinA = 9;
// For Motor B
const int MotorPinB = 13;
const int MotorSpeedPinB = 11;
const int MotorBrakePinB = 8;
const int forward = HIGH;
const int reverse = LOW;
QMC5883LCompass compass;
SoftwareSerial bluetooth(bluetoothRX, bluetoothTX);
int baseHeading = 0;
bool isBaselineSet = false;
bool isMovingForward = false;
bool isMovingBackward = false;
pinMode(MotorPinA, OUTPUT);
pinMode(MotorSpeedPinA, OUTPUT);
pinMode(MotorBrakePinA, OUTPUT);
pinMode(MotorPinB, OUTPUT);
pinMode(MotorSpeedPinB, OUTPUT);
pinMode(MotorBrakePinB, OUTPUT);
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
pinMode(buzzer, OUTPUT);
compass.init();
bluetooth.begin(9600);
if (bluetooth.available()) {
char receivedCommand = bluetooth.read();
if (receivedCommand == 'w') {
if (!isMovingForward) {
compass.read();
baseHeading = compass.getAzimuth();
isBaselineSet = true;
isMovingForward = true;
maintainDirection(forward);
} else if (receivedCommand == 'a') {
moveMotor('A', forward, 255);
moveMotor('B', reverse, 255);
} else if (receivedCommand == 's') {
if (!isMovingBackward) {
compass.read();
isMovingBackward = true;
maintainDirection(reverse);
} else if (receivedCommand == 'd') {
moveMotor('A', reverse, 255);
moveMotor('B', forward, 255);
} else if (receivedCommand == ' ') {
moveMotor('A', reverse, 0);
moveMotor('B', reverse, 0);
void moveMotor(char motor, int dir, int speed) {
int motorPin;
int motorSpeedPin;
if (motor == 'A') {
motorPin = MotorPinA;
motorSpeedPin = MotorSpeedPinA;
} else if (motor == 'B') {
motorPin = MotorPinB;
motorSpeedPin = MotorSpeedPinB;
digitalWrite(motorPin, dir);
analogWrite(motorSpeedPin, speed);
void maintainDirection(int direction) {
if (isBaselineSet) {
compass.read();
int currentHeading = compass.getAzimuth();
int error = currentHeading - baseHeading;
if (error < -180) {
error += 360;
} else if (error > 180) {
error -= 360;
int speedA = 255;
int speedB = 255;
if (error > 0) {
if (direction == forward) {
speedA = 255 - map(error, 0, 180, 0, 255);
speedB = 255 - map(error, 0, 180, 0, 255);
} else if (error < 0) {
speedB = 255 - map(-error, 0, 180, 0, 255);
speedA = 255 - map(-error, 0, 180, 0, 255);
moveMotor('A', direction, speedA);
moveMotor('B', direction, speedB);
Python code which sends the signals of WASD through bluetooth:
import pygame
import serial
ser = serial.Serial("COM3", 9600, timeout= 5)
pygame.init()
pygame.font.init()
FONT = pygame.font.SysFont("Arial", 30)
WINDOW_SIZE = 800
window = pygame.display.set_mode((WINDOW_SIZE, WINDOW_SIZE))
pygame.display.set_caption('TOGG 1X Bluetooth Controller')
BLACK = (0, 0, 0)
WHITE = (255, 255, 255)
RED = (255, 0, 0)
GRAY = (128, 128, 128)
SHAPE_SIZE = 250
ARROW_SIZE = 200
GAP_SIZE = 50
CENTER = WINDOW_SIZE // 2
CIRCLE_POS = (CENTER, CENTER)
UP_ARROW_POS = (CENTER, CENTER - SHAPE_SIZE // 2 - GAP_SIZE)
DOWN_ARROW_POS = (CENTER, CENTER + SHAPE_SIZE // 2 + GAP_SIZE)
LEFT_ARROW_POS = (CENTER - SHAPE_SIZE // 2 - GAP_SIZE, CENTER)
RIGHT_ARROW_POS = (CENTER + SHAPE_SIZE // 2 + GAP_SIZE, CENTER)
running = True
while running:
for event in pygame.event.get():
if event.type == pygame.QUIT:
running = False
keys = pygame.key.get_pressed()
window.fill(GRAY)
pygame.draw.circle(window, RED, CIRCLE_POS, SHAPE_SIZE // 2 + 5)
pygame.draw.polygon(window, BLACK, [(UP_ARROW_POS[0], UP_ARROW_POS[1] - ARROW_SIZE),
(UP_ARROW_POS[0] + ARROW_SIZE // 2, UP_ARROW_POS[1]),
(UP_ARROW_POS[0] - ARROW_SIZE // 2, UP_ARROW_POS[1])])
pygame.draw.polygon(window, BLACK, [(LEFT_ARROW_POS[0] - ARROW_SIZE, LEFT_ARROW_POS[1]),
(LEFT_ARROW_POS[0], LEFT_ARROW_POS[1] + ARROW_SIZE // 2),
(LEFT_ARROW_POS[0], LEFT_ARROW_POS[1] - ARROW_SIZE // 2)])
pygame.draw.polygon(window, BLACK, [(DOWN_ARROW_POS[0], DOWN_ARROW_POS[1] + ARROW_SIZE),
(DOWN_ARROW_POS[0] + ARROW_SIZE // 2, DOWN_ARROW_POS[1]),
(DOWN_ARROW_POS[0] - ARROW_SIZE // 2, DOWN_ARROW_POS[1])])
pygame.draw.polygon(window, BLACK, [(RIGHT_ARROW_POS[0] + ARROW_SIZE, RIGHT_ARROW_POS[1]),
(RIGHT_ARROW_POS[0], RIGHT_ARROW_POS[1] + ARROW_SIZE // 2),
(RIGHT_ARROW_POS[0], RIGHT_ARROW_POS[1] - ARROW_SIZE // 2)])
text_surface = FONT.render('W', True, WHITE)
window.blit(text_surface, (UP_ARROW_POS[0] - text_surface.get_width() // 2, UP_ARROW_POS[1] - 50))
text_surface = FONT.render('A', True, WHITE)
window.blit(text_surface, (LEFT_ARROW_POS[0] - 50, LEFT_ARROW_POS[1] - text_surface.get_height() // 2))
text_surface = FONT.render('S', True, WHITE)
window.blit(text_surface, (DOWN_ARROW_POS[0] - text_surface.get_width() // 2, DOWN_ARROW_POS[1] + 50))
text_surface = FONT.render('D', True, WHITE)
window.blit(text_surface, (RIGHT_ARROW_POS[0] + 50, RIGHT_ARROW_POS[1] - text_surface.get_height() // 2))
text_surface = FONT.render('SPACE', True, WHITE)
window.blit(text_surface, (CIRCLE_POS[0] - text_surface.get_width() // 2, CIRCLE_POS[1] - text_surface.get_height() // 2))
if keys[pygame.K_w]:
pygame.draw.polygon(window, WHITE, [(UP_ARROW_POS[0], UP_ARROW_POS[1] - ARROW_SIZE),
(UP_ARROW_POS[0] - ARROW_SIZE // 2, UP_ARROW_POS[1])], 4)
ser.write(b'w')
if keys[pygame.K_a]:
pygame.draw.polygon(window, WHITE, [(LEFT_ARROW_POS[0] - ARROW_SIZE, LEFT_ARROW_POS[1]),
(LEFT_ARROW_POS[0], LEFT_ARROW_POS[1] - ARROW_SIZE // 2)], 4)
ser.write(b'a')
if keys[pygame.K_s]:
pygame.draw.polygon(window, WHITE, [(DOWN_ARROW_POS[0], DOWN_ARROW_POS[1] + ARROW_SIZE),
(DOWN_ARROW_POS[0] - ARROW_SIZE // 2, DOWN_ARROW_POS[1])], 4)
ser.write(b's')
if keys[pygame.K_d]:
pygame.draw.polygon(window, WHITE, [(RIGHT_ARROW_POS[0] + ARROW_SIZE, RIGHT_ARROW_POS[1]),
(RIGHT_ARROW_POS[0], RIGHT_ARROW_POS[1] - ARROW_SIZE // 2)], 4)
ser.write(b'd')
if keys[pygame.K_SPACE]:
pygame.draw.circle(window, WHITE, CIRCLE_POS, SHAPE_SIZE // 2 + 5, 4)
ser.write(b' ')
if keys[pygame.K_ESCAPE]:
pygame.quit()
ser.close()
pygame.display.flip()
pygame.quit()
