How can I connect HC-06 to Arduino Motor shield that is functioning with 2 vibration motors
Basically you don't. The HC-06 must be wired to use a diffrent set of pins to the motor shield.
I get errors - avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync( when I upload codes to arduino
That means either the Arduino is not working, or you have chosen the wrong serial port, or something has been wired up that blocks the serial port.
How can I send commands to Arduino Serial Monitor from iOS Swift?
Best asking here:- Apple Developer Forums
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom..
