Problems with NetBeans IDE
I want to use netbeans for developmet under linux and followed this guide: http://playground.arduino.cc/Code/Netbeans
I managed to compile the core library and the simple blink example but after downloading it to the ethernet baord (LED is on Pin 9) it just glows half and flickers a littel bit.
I allready compared the compiler switches of the arduino ide and the netbeans ide!
Does anyone know what might be the problem?
thanks, max
Now I tried to compile the whole project, named ardionoall, at once including the sources of the core library and the blink-code but still the same behaviour ... The LED just glows very low.
Here is the compiling output from netbean ide, maybe someone can find a bad compiler switch or something else:
http://pastebin.com/WzqaBMXU
Every hint is welcome!
thanks, max
Hello Max,
I don't no about the problem, but you can try this plugin for netbeans: http://plugins.netbeans.org/plugin/46054/arduino
Regards, Jaques
