Problems with nRF24L01+
I recently bought two "SparkFun Transceiver Breakout - nRF24L01+ (RP-SMA)" and the antenna. I am using an Arduino Uno to receive, and an ATtiny85 @8Mhz to send, just very basic communication. My Arduino receiving code is below with the hookup in it.
  Getting Started example sketch for nRF24L01+ radios
  This is a very basic example of how to send data from one node to another
  Updated: Dec 2014 by TMRh20
*****PINOUT*****
VCC - 5Vdc
CE - Arduino pin 7
CSN - Arduino pin 8
SCK - Arduino pin 13
MOSI - Arduino pin 11
MISO - Arduino pin 12
IRQ -
GND - GND
*****PINOUT*****
#include <SPI.h>
#include "RF24.h"
/****************** User Config ***************************/
/***      Set this radio as radio number 0 or 1         ***/
int radioNumber = 0;
const int CE_PIN = 7;
const int CSN_PIN = 8;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(CE_PIN, CSN_PIN);
byte addresses[][6] = {"1Node", "2Node"};
int datarecv;
  Serial.println("RF24/examples/GettingStarted");
  radio.begin();
  radio.setChannel(108);
  // Set the PA Level low to prevent power supply related issues since this is a
  // getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
  radio.setPALevel(RF24_PA_LOW);
  if (radioNumber == 0) {
    radio.openWritingPipe(addresses[1]);        // Both radios listen on the same pipes by default, but opposite addresses
    radio.openReadingPipe(1, addresses[0]);     // Open a reading pipe on address 0, pipe 1
    radio.openWritingPipe(addresses[0]);
    radio.openReadingPipe(1, addresses[1]);
  // Start the radio listening for data
  radio.startListening();
  if (radio.available())
    while (radio.available())
      radio.read( &datarecv, sizeof(datarecv) );
    Serial.print("DATE RECIVED:  ");
    Serial.println(datarecv);
My ATtiny85 sending code is below. I am using the first pinout hookup.
  This program is free software; you can redistribute it and/or
  modify it under the terms of the GNU General Public License
  version 2 as published by the Free Software Foundation.
    rf24ping85.ino by tong67 ( https://github.com/tong67 )
    This is an example of how to use the RF24 class to communicate with ATtiny85 and other node.
    Write this sketch to an ATtiny85. It will act like the 'transmit' mode of GettingStarted.ino
    Write GettingStarted.ino sketch to UNO (or other board or RPi) and put the node in 'receiver' mode.
    The ATtiny85 will transmit a counting number every second starting from 1.
    The ATtiny85 uses the tiny-core by CodingBadly (https://code.google.com/p/arduino-tiny/)
    When direct use of 3v3 does not work (UNO boards have bad 3v3 line) use 5v with LED (1.8V ~ 2.2V drop)
    For low power consumption solutions floating pins (SCK and MOSI) should be pulled high or low with eg. 10K
    ** Hardware configuration **
    ATtiny25/45/85 Pin map with CE_PIN 3 and CSN_PIN 4
                   NC      PB5  1|o   |8  Vcc --- nRF24L01  VCC, pin2 --- LED --- 5V
    nRF24L01  CE, pin3 --- PB3  2|    |7  PB2 --- nRF24L01  SCK, pin5
    nRF24L01 CSN, pin4 --- PB4  3|    |6  PB1 --- nRF24L01 MOSI, pin7
    nRF24L01 GND, pin1 --- GND  4|    |5  PB0 --- nRF24L01 MISO, pin6
    ATtiny25/45/85 Pin map with CE_PIN 3 and CSN_PIN 3 => PB3 and PB4 are free to use for application
    Circuit idea from http://nerdralph.blogspot.ca/2014/01/nrf24l01-control-with-3-attiny85-pins.html
    Original RC combination was 1K/100nF. 22K/10nF combination worked better.
	For best settletime delay value in RF24::csn() the timingSearch3pin.ino scatch can be used.
    This configuration is enabled when CE_PIN and CSN_PIN are equal, e.g. both 3
    Because CE is always high the power consumption is higher than for 5 pins solution
                                 +-\/-+           nRF24L01   CE, pin3 ------|              //
                           PB5  1|o   |8  Vcc --- nRF24L01  VCC, pin2 ------x----------x--|<|-- 5V
                   NC      PB3  2|    |7  PB2 --- nRF24L01  SCK, pin5 --|<|---x-[22k]--|  LED
                   NC      PB4  3|    |6  PB1 --- nRF24L01 MOSI, pin6  1n4148 |
    nRF24L01 GND, pin1 -x- GND  4|    |5  PB0 --- nRF24L01 MISO, pin7         |
                        |-----------------------------------------------||----x-- nRF24L01 CSN, pin4
        10nF
    ATtiny24/44/84 Pin map with CE_PIN 8 and CSN_PIN 7
	Schematic provided and successfully tested by Carmine Pastore (https://github.com/Carminepz)
    nRF24L01  VCC, pin2 --- VCC  1|o   |14 GND --- nRF24L01  GND, pin1
                            PB0  2|    |13 AREF
                            PB1  3|    |12 PA1
                            PB3  4|    |11 PA2 --- nRF24L01   CE, pin3
                            PB2  5|    |10 PA3 --- nRF24L01  CSN, pin4
                            PA7  6|    |9  PA4 --- nRF24L01  SCK, pin5
    nRF24L01 MOSI, pin7 --- PA6  7|    |8  PA5 --- nRF24L01 MISO, pin6
#include "RF24.h"
// CE and CSN are configurable, specified values for ATtiny85 as connected above
#define CE_PIN 3
#define CSN_PIN 4
//#define CSN_PIN 3 // uncomment for ATtiny85 3 pins solution
int radioNumber = 1;
int i = 0;
unsigned long payload = 0;
  // Setup and configure rf radio
  radio.begin(); // Start up the radio
  radio.startListening(); // Start listening
void loop(void) {
  radio.stopListening();
  radio.write( i, sizeof(i) );
  i++;
The first problem is that the flow of data is not there. In serial monitor it displays one then nothing, or displays 10 very fast then nothing.
The second problem, and more concerning to me, is that the breakout hooked up to the Arduino is hot to the touch. I am not sure it is hooked up correctly.
Can I define, MOSI, MISO, IRQ, and SCK pins to verify correct pinout? This article, https://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo#lib , talks about intermittent operation and lack of current. But, I am using an 80 W power supply and the amperage reading is only 0.3 peak, with an ATtiny85 and two RF breakouts on it.
Have a look at this Simple nRF24L01+ Tutorial.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
...R
