Problems with optiboot and arduinoISP
I have been trying for a few hours to load optiboot 5.0 to an ATmega328p, using windows 7 with arduinoISP as the programmer, here is what I have tried so far.
Burn optiboot loader from arduino IDE, chip programmed and here is the tail of the message
avrdude: Recv: . [10]
# | 100% 30.15s
avrdude: verifying ...
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | avrdude: Send: V [56] X [58] . [00] . [00] . [00]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [ff]
avrdude: Send: V [56] . [ac] . [e0] . [00] . [cf]   [20]
avrdude: Recv: . [00]
avrdude: Recv: . [cf]
################################################## | 100% 0.05s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | avrdude: Send: V [56] X [58] . [00] . [00] . [00]   [20]
################################################## | 100% 0.03s
avrdude: 1 bytes of lock verified
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
When I try to then upload a sketch using the [optiboot] duemilanove or nano w/ 328p board option I get a signature error
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [05]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
         Hardware Version: 3
         Firmware Version: 5.0
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Also using the same ArduinoISP setup I have tried
Tried a ATmega168 with optiboot 5.0 168 firmware, program & verify ok, arduino IDE gives the same error
I have tried optiboot version 4.4 on both an ATmega328 & 168, programs & verify ok, arduino IDE gives the same error
Programmed from the command line with avrdude 5.10 & 5.11, programs & verify ok, arduino IDE gives the same error
From the command line direct upload of blink hex file worked ok
Burned a standard boot loader from arduino IDE & command line both will now accept sketches from arduino IDE
It has to something I am missing be grateful for any pointers
Ian
Missed a bit of information
using a duemilanove with 328p as the ArduinoISP board
Huh. Weird. You downloaded the .zip and burned one of the existing .hex files (optiboot_atmega328.hex) ?
I checked the 328 .hex file and all the .lst files, and they all seem to contain correct signatures (not zeros.)
Can you include the full avrdude log from the "burn bootloader" step?
Yes, just downloaded the optiboot zip file today
I have attached a .7z file, I think it is what you where after, let me know if you need anything else.
I feel I have done everything correct especially as I can burn a standard boot loader in the same manner, but then, it could still be me.
Thanks for taking a look
Ian
fullArduinoISP.7z (3.67 KB)
What board type are you selecting when you try downloading the sketch?
I think you need to select Uno, altho your hardware platform may actually be something else.
Hi
I am selecting the "[optiboot] Arduino duemilanove or nano w/ ATmega328", as the boot loader comes with these board types, kind of assumed it would be the correct one, wait one upload..... yup, that has fixed the problem.
So to recap you flash the boot loader by selecting the target board as "[optiboot] Arduino duemilanove or nano w/ ATmega328", but when you flash the sketch you select the "nano" :slight_smile: I should have tried nano but went off at a tangent with command line and everything else, it does make sense as I believe the optiboot loader is the bootloader used by the uno, still it was an educational few hours.
Thank you very much
Ian
Ah hah! AVRDUDE is using the "Universal" command ("V") to try to read the signature.
Optiboot does not support this command and always returns zero, so avrdude is reporting a signature of 000000.
This is because the boards.txt provided with optiboot is wrong; It has "name.upload.protocol=stk500" for all the board types that it defines, which predates the existence of "name.upload.protocol=arduino" The old protocol will work with older versions of avrdude, but apparently not the latest version.
Change the occurences of "stk500" in the boards.txt file to "arduino", and you should get better results.
This is Google Code Archive - Long-term storage for Google Code Project Hosting.
This thread really helped me out. Thank you so much!
