Hello nice people of the internet,
I have been trying to create a quadruped spider robot. For this reason, I need to define movements such as move_left() or move_right().
If I just let the servos move to another angle at their own speeds, the legs do not synchronize and the robot just keeps sliding on the ground.
As such, I need several servos to move at the same time, for exactly a specified amount of time.
Using delay()'s for this purpose is not practical, as there could be a case where:
Joint 4 is commanded to move to position X in 3 seconds.
At 0.5 seconds, joint 4 receives another command which would override as the first command still needs 2.5 seconds to finish.
Using delays and busy waits interferes with the movement of the first command. As such, I am using interrupts.
Long story short, given the following code, the command line of Arduino produces expected results, but physically the servos just keep moving randomly.
So I suspect if the PCA9685 does not work so well with interrupts? Or am I missing something here?
I am using Arduino Uno , PCA9685 PWM Generator, SG90 Servo to make things work.
Looking forward to your responses.
Code:
// | D9 | | D7 |
// | joint9 | | joint7 |
// | Foot 3 | | Foot4 |
// | D8 | | D6 |
// | joint10 | | joint6 |
// | Foot2 | | Foot1 |
// | D2 | | D4 |
// | joint2 | | joint4 |
// | D3 | | D5 |
// | joint3 | | joint5 |
// Front
#define I2CAdd 0x40 // Define the I2C address of PCA9685
//#include <Servo.h> //Call servo Library
#include "HCPCA9685.h" //Call PCA9685 library
#include <FlexiTimer2.h>
HCPCA9685 HCPCA9685(I2CAdd);
* Unsigned char is used rather than unsigned int for saving memory.
* RELEVANT: Yes, interrupts occur, and are processed, during delay functions.
* When the ISR finishes, and returns, the code that was executing resumes executing
* where it left off. If a delay was in process, the delay will be resumed.
* The delay will end at the same time it would have if the interrupt had not occurred
typedef struct Joint
bool isMoving;
unsigned long moveTimeSoFar;
unsigned long targetTime;
unsigned int currAngle;
unsigned int targetAngle;
} Joint;
const unsigned char JOINT_COUNT = 8;
Joint joints[JOINT_COUNT];
// Initialize joints
int defaultAngles[8] = {250, 40, 140, 350, 250, 40, 160, 350};
int i;
for (i = 0; i < JOINT_COUNT; i++)
joints[i].targetAngle = 0;
joints[i].targetTime = 0;
joints[i].isMoving = false;
joints[i].moveTimeSoFar = 0;
joints[i].currAngle = defaultAngles[i];
FlexiTimer2::set(20, checkMovements);
FlexiTimer2::start();
// Here, specify which move to start, e.g.:
startTimedMovement(4, 150, 3000);
startTimedMovement(5, 220, 3000);
void startTimedMovement(unsigned char jointId, unsigned int targetAngle, unsigned long targetTime)
joints[jointId].targetTime = targetTime;
joints[jointId].targetAngle = targetAngle;
joints[jointId].isMoving = true;
joints[jointId].moveTimeSoFar = 0;
// No need to do anything here, as the loop is handled by the checkMovements(void) interrupt
void wait_all_reach(void)
for (int i = 0; i < JOINT_COUNT; i++)
while(1) if(joints[i].moveTimeSoFar > joints[i].targetTime) break;
void checkMovements(void)
sei();
unsigned long currentTime = millis();
int i;
if (joints[i].isMoving)
// Target time has been reached
if (joints[i].moveTimeSoFar > joints[i].targetTime)
{ // Still need to move more
joints[i].currAngle = map(
joints[i].moveTimeSoFar, // Current progress
0, // Start time
joints[i].targetTime, // End time
joints[i].currAngle,
joints[i].targetAngle);
joints[i].moveTimeSoFar = currentTime;
Serial.println("Servo " + String(i) + " moves to angle " + String(joints[i].currAngle) + ". MoveTimeSoFar " + String(joints[i].moveTimeSoFar));
HCPCA9685.Servo(i, joints[i].currAngle);
Serial.println("It took function " + String(millis() - currentTime) + " seconds to complete");
**OUTPUT** (It is as expected as both servos move at the same time with each tick)
Servo 4 moves to angle 250. MoveTimeSoFar 48
15:03:49.643 -> Servo 5 moves to angle 40. MoveTimeSoFar 48
15:03:49.689 -> It took function 27 seconds to complete
15:03:49.783 -> Servo 4 moves to angle 249. MoveTimeSoFar 119
15:03:49.783 -> Servo 5 moves to angle 42. MoveTimeSoFar 119
15:03:49.877 -> It took function 96 seconds to complete
15:03:49.877 -> Servo 4 moves to angle 246. MoveTimeSoFar 258
15:03:49.923 -> Servo 5 moves to angle 49. MoveTimeSoFar 258
15:03:50.017 -> It took function 97 seconds to complete
15:03:50.017 -> Servo 4 moves to angle 238. MoveTimeSoFar 397
15:03:50.065 -> Servo 5 moves to angle 63. MoveTimeSoFar 397
15:03:50.112 -> It took function 97 seconds to complete
15:03:50.159 -> Servo 4 moves to angle 227. MoveTimeSoFar 537
15:03:50.251 -> Servo 5 moves to angle 83. MoveTimeSoFar 537
15:03:50.251 -> It took function 96 seconds to complete
15:03:50.299 -> Servo 4 moves to angle 214. MoveTimeSoFar 676
15:03:50.346 -> Servo 5 moves to angle 107. MoveTimeSoFar 676
15:03:50.394 -> It took function 98 seconds to complete
15:03:50.441 -> Servo 4 moves to angle 200. MoveTimeSoFar 816
15:03:50.489 -> Servo 5 moves to angle 132. MoveTimeSoFar 816
15:03:50.581 -> It took function 98 seconds to complete
15:03:50.581 -> Servo 4 moves to angle 187. Mov
