Problems with Pololu 18v25 CS High Power Motor Driver
How to control a a dc motor using a Pololu High-Power Motor Driver 18v25 CS and an arduino uno ?
There is a lot of information on the Pololu website.
What are you having a problem with? What do you not understand?
...R
I need to see the connections of pins from motor driver to arduino. I tried the way as mentioned in the website but motor driver is not giving any voltage across OUTA snd OUTB.
I have connected a pwm pin to PWMH, groud to ground, direction to a digital pin and digital pin to PWML and an external supply of 12 volts across V+ and GND of motor driver. This is the code I have used:
const int dir = 2;
const int pwmh = 3;
const int pwml =4 ;
  pinMode(pwmh, OUTPUT);
  pinMode(dir, OUTPUT);
  pinMode(pwml, OUTPUT);
  digitalWrite(pwml, HIGH);
  delay(2000);
  analogWrite(pwmh,250);
  digitalWrite(dir,HIGH);
  delay(3000);
Make a pencil drawing showing how you have everything connected and post a photo of the drawing. Please don't use Fritzing.
A drawing is much less likely to be misunderstood compared to a verbal description.
...R
And don't forget to monitor the fault flag outputs, that could be important information.
A clear wiring diagram (make sure to double-check so you show the precise setup you are using) plus the code is vital for us to fault-find. Tell us what currentyour 12V supply can produce and what your motor is.
how to connect a 18v dc geared motor to arduino mega 2560 ?....and how to control it ?
karthikeyan593: how to connect a 18v dc geared motor to arduino mega 2560 ?....and how to control it ?
How does this help @vyshakhmn ?
...R
This is the connection . The voltage supply i have used is a variable dc power source with a max current rating of 10 A . The dc motor is a normal 300 rpm dc motor which works when directly connected to the v+ and gnd.
I havent checked the flags.
the code is posted in a previos post.
Well check the flags - if the controller is in a fault condition it won't be powering the motor.
how should i check the flag (the connection and the code) :D ?
Both flags were low when I checked it. should I connect reset to ground ?
i bought a high torque dc geared motor rmcs-2005 and motor drive rmcs-2302....how to connect them to the arduino board mega 2560 ? how to control the speed of the motor ?
Reset should be connected and held high.
https://www.pololu.com/product/1455
vyshakhmn: Both flags were low when I checked it.
Then its not detecting an error state. Eliminate all the possible problems till it works or you know what the issue is.
