Problems with readStringUntil
Hello,
i'm trying to use the function readStringUntil('\r') to store a in a String variable a message received from a tcp client and perform some actions...
When i call
String str = client.readStringUntil('\r');
Serial.println(str);
some seconds later i receive a strange reply in Serial monitor.
This is what i received
if in the tcp client i wrote something, i receive, only for the first print these carachters and then the string i put in the tcp client.
Any idea?
looks like different baudrates between what is defined in the
Serial.begin();
command
and the actual baudrate that the serial monitor is adjusted to.
best regards Stefan
Thanks, i found that the problem is in the app that i'm using to test the script.
An app for iOS that send a connection confirmation any time i connect to the socket.
Use of another app solves the problem.
Thanks anyway.
Regards
