problems with robot using ultrasonic sensor to avoid obstacles [solved]
Hi
@jorpec thanks again. I'll try the setting one motor higher trick. I am using pins that do work with analogWrite() .
-p.
Wow I really have to stop getting on the forum at midnight :sleeping: . @jorpec I just looked at your other topic concerning using an IR sensor to let the robot "see" things off to the side and not hit them and I think I'll have to add a servo or something to turn the Ultrasonic sensor to "see" more, something like "check right, left and forwards an if there's nothing within 20 cm go forwards." Of course that is a lot simpler than what I'll actually have to program it to do but you probably get the idea. Since I haven't tried to code this yet I don't know if I'll have to ask the community for help but I'm just putting this information out there in case anyone wonders where that new snippet of code came from. Again sorry if I'm incoherent, it's late.
-p.
My robot has a servo attached to the ultrasonic sensor, but only moves left or right when it "see" something, in your case if the servo moving left and right constantly i guess it will "see" obstacles on a wider angle
Hi
I changed all pwm2 values from 100 to 125 and that solved the motor speed difference problem.
I also just changed the time the LED was on during setup from 5 seconds to 2 seconds. New code:
const int pwm1 = 11;//left motor
const int in1 = 10;//left backward
const int in2 = 9;//left forward
const int pwm2 = 6;//right motor
const int in3 = 5;// right backward
const int in4 = 4;// right forward
const int led = 13;
const int pingPin = 7;
  pinMode (pwm1, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(pwm2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  pinMode(led, OUTPUT);
  digitalWrite(in1, LOW);//added2
  analogWrite(pwm1, 0);//added3, is this necessary? speed control
  digitalWrite(in2, HIGH);//left motor forward
  analogWrite(pwm1, 100);//speed control
  digitalWrite(in3, LOW);//added2
  analogWrite(pwm2, 0);//added3, is this necessary? speed control
  digitalWrite(in4, HIGH);//right motor forward
  analogWrite(pwm2, 125);//speed control
  digitalWrite(in2, LOW);
  analogWrite(pwm1, 0);//speed control
  digitalWrite(in4, LOW);
  analogWrite(pwm2, 0);//speed control
  digitalWrite(in1, HIGH);// left motor backwards
  digitalWrite(in3, HIGH);//right motor backwards
  digitalWrite(led, HIGH);//led on for five seconds
  delay(2000);//changed from 5 sec to 2 sec
  digitalWrite(led, LOW);// led off
  Serial.begin(9600);// stops doing what i want it to do here
void loop(){
  analogWrite(pwm1, 0);//added, speed control
  analogWrite(pwm2, 0);//added, speed control
  digitalWrite(in2, HIGH);//left motor forwards
  digitalWrite(in4, HIGH);//right motor forwards
  uint8_t i;
  long duration, inches, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin,HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  cm = microsecondsToCentimeters(duration);
  Serial.print(cm);
  Serial.print("cm");
  if (cm >20){
    digitalWrite(in1,LOW);//added
    digitalWrite(in2, LOW);//left motor, backwards
  //for (i=0; i<255; i++){ i can't even remember why i commented this out. any ideas?
 // delay(10);}
  digitalWrite(in3,LOW);//added
  digitalWrite(in4, LOW);// right motor, backwards
  delay(10);}
digitalWrite(in3, LOW);//start both motors forward again
analogWrite(pwm2, 0);// added, is this one of the parts you were talking about? speed control
analogWrite(pwm2, 125);//added, speed control
analogWrite(pwm1,0);//added, speed control
analogWrite(pwm1, 100);//added, speed control
delay(30);
  else{
    digitalWrite(in2, HIGH);//keep going straight
  long microsecondsToCentimeters(long microseconds)
    return microseconds / 29/ 2;}
-p.
Hi
Sorry for not getting around to this sooner but I am going to declare this solved. I realized as I learned more about Arduino that I don't know what the code I was basing mine off of was trying to do, because it literally makes the robot back off and then run into the wall. Or at least my changed up one did, probably a part I missed. I will keep working on my project, incorporating turning and probably more sensors. So the issues this topic was on are solved (that's not saying that there won't be more) though my robot is far from done! Thanks everyone for your time and help!
-p.
