Hi, everyone. I have some problems with send my GPS data to IOT sap hana cloud. When I try to do this,I have Exit value 22. So, it means thatthe curl received the bad request(400 status), but data is correct. If I try to send message without Tiny library, I send data, but It is not GPS data. How can I send data without library Process, and use HttpClient for send my data or maybe I can send the data other option.
There is my code.
#include <TinyGPS.h>
#include <SoftwareSerial.h>
#include <Process.h>
#include <HttpClient.h>
SoftwareSerial gpsSerial(8, 7); // create gps sensor connection
TinyGPS gps; // create gps object
Bridge.begin();
Serial.begin(9600); // connect serial
gpsSerial.begin(9600); // connect gps sensor
float lat, lon;
GET_GPS();
void GET_GPS()
while (gpsSerial.available()) { // check for gps data
if (gps.encode(gpsSerial.read())) { // encode gps data
//lol+= char(gpsSerial.read());
//Serial.write(char(gpsSerial.read()));
gps.f_get_position(&lat, &lon);
Serial.print("lat: "); Serial.print(lat, 6); Serial.print(" "); // print latitude
Serial.print("lon: "); Serial.println(lon, 6); // print longitude*/
pushToCloud1(lat, lon);
void pushToCloud1(float Lot, float Lat)
Process p;
p.begin("curl");
p.addParameter("-k");
p.addParameter("-f");
p.addParameter("-H");
p.addParameter("Authorization: Bearer " + TOKEN);
p.addParameter("Content-Type: application/json;charset=UTF-8");
p.addParameter("-X");
p.addParameter("POST");
//p.addParameter("https://iotmmsp1942369040trial.hanatrial.ondemand.com/com.sap.iotservices.mms/v1/api/http/data/c2721cd2-3e96-4858-9cb6-7fb5d0c7a29e");//TLH
p.addParameter("https://iotmmsp" + NAME_ACCOUNT + ".hanatrial.ondemand.com/com.sap.iotservices.mms/v1/api/http/data/9d791d17-f73f-47d7-941b-69ea6c670939"); //geo
p.addParameter("--data");
String str1;
char tmp1[10];
char tmp2[10];
dtostrf(Lot, 1, 6, tmp1);
String strLab1 = "";
String strOut1 = strLab1 + tmp1;
dtostrf(Lat, 1, 6, tmp2);
String strLab = "";
String strOut = strLab + tmp2;
str1 = "{\"mode\":\"async\",\"messageType\":\"" + MESSAGE + "\",\"messages\":[{\"timestamp\":" + String(0) + ",\"Latitude\":" + String(strOut1) + ",\"Longitude\":" + String(strOut) + "}]}";
p.addParameter(str1);
p.run();
Serial.println(str1);
Serial.print("Exit: ");
Serial.println(p.exitValue());
