I've been trying to get an Arduino and ESP8266 to communicate with each other over serial. The ESP8266 uses the Serial
class for communications, while the Arduino uses SoftwareSerial
The problem is that when I try to send data from the Arduino to the ESP8266, only the first character of the string sent gets received by the ESP8266. For example, if I send a string "leather", the ESP8266 only receives an 'l'. Both devices are operating at 38400 baud, although I have tried 9600 baud with similar results (apparently SoftwareSerial
is more reliable at lower baud rates).
Here is the relevant code that's running on both devices:
Arduino code:
#include <stdlib.h>
#include <SoftwareSerial.h>
#define COMMAND_TILT 'c'
#define SOFTWARE_SERIAL_BAUD_RATE 38400
#define ESP_RX 8
#define ESP_TX 9
SoftwareSerial esp(ESP_RX, ESP_TX);
esp.begin(SOFTWARE_SERIAL_BAUD_RATE);
if (esp.available() > 0) {
String data;
while (esp.available() > 0) {
data += (char) esp.read();
char command = data.charAt(0);
data.remove(0, 1);
int value = data.toInt();
char buf[STR_BUF_LEN];
switch (command) {
case COMMAND_TILT:
sprintf(buf, "%c%d", COMMAND_TILT, value);
esp.write(buf);
delay(100);
ESP8266 code:
#define SERIAL_BAUD_RATE 38400
Serial.begin(SERIAL_BAUD_RATE);
if (Serial.available() > 0) {
String data;
while (Serial.available() > 0) {
data += (char) Serial.read();
data.remove(0, 1);
// problem: now, data.c_str() is blank when it should contain an integer in string format
delay(100);
If it helps to know, I'm running an MQTT client on the ESP8266 and controlling some steppers and relays on the Arduino.
