Problems with serial port
Good night.
I’m a beginner with Arduino and I’m in need of help.
I have a program that sends data to the Arduino’s serial port (azimuth and elevation) of a given satellite.
I made a code for satellite tracking where I use a Mega board with the HCM5883 sensor, a nextion display and relays.
The idea is to compare the data of the sensor with the received through the serial port and thus, to turn on or off relays that drive two motors that move the antenna.
My problem is that while the program is sending the data to the serial port, I can not but read the sensor data.
I noticed on the Mega board that when the data was received by the serial, the TX LED blinks every second while the RX LED, which used to sting rapidly, practically stopped. It flashes approximately every 15 seconds. If you stop sending the data by serial, the RX led returns to normal.
Sorry for my English.
Can someone help me?
Please post your full sketch.
If possible, you should always post code directly in the forum thread as text using code tags:
  • Do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code. This will make it easier for you to spot bugs and make it easier for us to read.
  • In the Arduino IDE or Arduino Web Editor, click on the window that contains your sketch code.
  • Press “Ctrl + A”. This will select all the text.
  • Press “Ctrl + C”. This will copy the selected text to the clipboard.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the sketch between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Repeat the above process if your sketch has multiple tabs.
This will make it easy for anyone to look at it, which will increase the likelihood of you getting help.
If the sketch is longer than the 9000 characters maximum allowed by the forum, then it’s OK to add it as an attachment. After clicking the “Reply” button, you will see an “Attachments and other settings” link.
When your code requires a library that’s not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
