Problems with SerialPrint.
Hey guys, it's been a long time since I used an Arduino. I just downloaded the latest version of the program and I found something I want to try but I think the code is a bit old haha, I tried some stuff but there's always a new error, this is the code.
int Forward = 2;
int Backward = 3;
int Left = 4;
int Right = 5;
int Low_Limit = 88;
int High_Limit = 168;
  // begin the serial communication
  Serial.begin(38400);
  // Set Output pins
  pinMode(Forward, OUTPUT);
  pinMode(Backward, OUTPUT);
  pinMode(Left, OUTPUT);
  pinMode(Right, OUTPUT);
  byte x,y;
  while (!Serial.available());
  if (Serial.available() >0 ) {
    x = Serial.read();
     Serial.print(x, BYTE);
    y = Serial.read();
     Serial.print(y,BYTE);
  // Back and forward
  if ( x > High_Limit)
      digitalWrite(Forward, HIGH);
      digitalWrite(Backward, LOW);
  else if( x < Low_Limit)
     digitalWrite(Forward, LOW);
     digitalWrite(Backward, HIGH);
  //Left and Right
  if ( y > High_Limit)
      digitalWrite(Right, HIGH);
      digitalWrite(Left, LOW);
  else if( y < Low_Limit)
     digitalWrite(Right, LOW);
     digitalWrite(Left, HIGH);
What could I do?
The error, which you sadly did not post, was:
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
Perhaps you should user Serial.write ?
I changed it, but now this is the code
int Forward = 2;
int Backward = 3;
int Left = 4;
int Right = 5;
int Low_Limit = 88;
  // Set Output pins
  byte x,y;
    x = Serial.read();
    y = Serial.read();
  // Back and forward
  //Left and Right
And a new error appears and this is the new error.
carrito.ino: In function 'void loop()':
carrito:27: error: expected primary-expression before ')' token
carrito:32: error: expected primary-expression before ')' token
What should I do? I've been investigating but I can't see the mistake. I know it's going to be something really basic.
Thank you for your help.
I pasted your code into 0022. I got this "error" message:
Binary sketch size: 2512 bytes (of a 30720 byte maximum)
chemariachi:
I changed it
Doesn't look like it:
You might have changed it, but the code you posted still has the BYTE keyword.
