I connected an 7.5v lithium battery with 5v voltage regulator to one servo motor and connected the signal wite to ardino pin 10 and connected an ground wire to gnd in ardino.
For your info:
I am using
Ardino UNO smd
Lm7805 5v regulator
Breadboard
Lithium battery of 7.5v
Mg90s Servo motor
So please kindly help me with this
the above mentioned was basic step of my project, let me provide you with the entire project.
I have 4 ldr and we run servo motor with the difference between the intensity in LDR's, which controls the horizontal and vertical servo motors.
let me provide you the entire code
// C++ code
#include <Servo.h>
Servo servohori; //horizontal servo(BOTTOM SERVO)
int servoh = 0; //assign servo at 0 degree
int servohLimitHigh = 180; //maximum range of servo is 180 degree(it is variable you can also change)
int servohLimitLow = 10; //minimum range of servo is 10 degree(it is variable you can also change)
Servo servoverti; //vertical servo(TOP SERVO)
int servov = 0;
int servovLimitHigh = 180;
int servovLimitLow = 10;
int ldrtopr = 1; //top right LDR A1 pin
int ldrtopl = 2; //top left LDR A2 pin
int ldrbotr = 0; // bottom right LDR A0 pin
int ldrbotl = 3; // bottom left LDR A3 pin
void setup ()
servohori.attach(10); //horizontal servo connected to arduino pin 10
servohori.write(0);
servoverti.attach(9); //vertical servo connected to arduino pin 9
servoverti.write(0);
delay(500); //delay
servoh = servohori.read();
servov = servoverti.read();
int topl = analogRead(ldrtopl); //read analog values from top left LDR
int topr = analogRead(ldrtopr); //read analog values from top right LDR
int botl = analogRead(ldrbotl); //read analog values from bottom left LDR
int botr = analogRead(ldrbotr); //read analog values from bottom right LDR
// Print LDR values to Serial Monitor
Serial.print(topl);
Serial.print(",");
Serial.print(topr);
Serial.print(",");
Serial.print(botl);
Serial.print(",");
Serial.println(botr);
int avgtop = (topl + topr) / 2; //average of top LDRs
int avgbot = (botl + botr) / 2; //average of bottom LDRs
int avgleft = (topl + botl) / 2; //average of left LDRs
int avgright = (topr + botr) / 2; //average of right LDRs
if (avgtop < avgbot)
servoverti.write(servov -1);
if (servov > servovLimitHigh)
servov = servovLimitHigh;
delay(8);
else if (avgbot < avgtop)
servoverti.write(servov +1);
if (servov < servovLimitLow)
servov = servovLimitLow;
delay(8);
servoverti.write(servov);
if (avgleft > avgright)
servohori.write(servoh -1);
if (servoh > servohLimitHigh)
servoh = servohLimitHigh;
delay(8);
else if (avgright > avgleft)
servohori.write(servoh +1);
if (servoh < servohLimitLow)
servoh = servohLimitLow;
delay(8);
servohori.write(servoh); // write means run servo
delay(50);
