good since I started with arduino I had no problem when programming leds dc motors but in a matter of servos have some difficulty since more I use servo model hs-311 that are a little stronger than the 7 grams of torque so wanted to see if anyone could help me to see a circuit not directly connect multiple servos to direct feeding arduino but with a separate source with the signal from arduino someone who could help me with schematic or another solution
Hmmmm that was a long sentence to read with no pauses, and I’m not sure exactly what you’re asking, but I think you need the attached.
hmm.. in the image above, looks like the servos are connected in parallel..so shouldnt about 6-7 V be enough to run N number of servo motors??
silvergravel:
Yes exactly: 4.8 to 6 in fact. It's the current which is usually the issue. You need a source which can sustain that voltage at about 1A per motor.
o okay thanks jimbo. so here in india we receive 220 v in our plug points. was thinking of using a 5-6 volt adapter out of the electricity socket. should be a good enough source to sustain the voltage?
or would the 5 v from the arduino board ( connected to the laptop ) be good enough?
silvergravel:
Budget 1A per servo and then choose an adapter that can provide 6V at that current, say 2 or 3 or whatever amps it adds up to.
silvergravel:
No.... we've all probably used that 5V for testing one micro servo with no load, but as soon as you ask the servo to do any real mechanical work, and / or have more than one servo, it can't provide enough current. From memory- and I may be wrong- the Arduino can provide 0.5A total to everything it's doing, so for all practical purposes, it's no good for servo power.
k got it. thanks so much! one last question it has to be DC right?
silvergravel:
Indeed
thank you very much to Jimboza by the chart now if I can do my project without feeding problems servomotor
thanks jimboZA
