Problems with size of array
Why is
const int pins[6] = {5,6,7,8};
const int numOfPins = sizeof(pins);
returning (with a Serial.print):
numOfPins = 12 ????? and not 4?? because there are 4 items in the array??
sizeof returns the number of bytes in an array. An int (2 bytes) array of 6 elements holds 12 bytes. If you want the number of elements, divide the number of bytes in the array by the number of bytes in the data type. sizeof(array)/sizeof(array[0]) for instance or sizeof(array)/sizeof(int).
When in doubt, there's always the reference
groundfungus has shown you a common idiom for finding array size:
#define ELEMENTS(x) (sizeof(x)/sizeof(x[0]))   // At top of program, outside any function, with global scope
// more code
// perhaps the following is in loop()
   float pressure[10];
// read some pressure sensors...
// ...now show them...
   for (int i = 0; i < ELEMENTS(pressure); i++) {
      Serial.print(pressure[i]);
One of the nice things about this parameterized macro is that it is “typeless”. That is, you can use it with whatever data type you need: char, float, int…whatever.
Ok, thanks !! it works perfect!!
but another question:
how can I fill the matrix
instead of using:
byte addresses[][6] = {"1Node", "2Node", "3Node", "4Node"};
with something like:
  for (int i=0; i< ELEMENTS(pins); i++) {
    addresses[i][6] = i + "Node";
But the code above doesn’t work :frowning:
...and yet another demonstration of why you should use code tags when posting code. (A six element array doesn't have index 6, and you can't add strings and ints. - try sprintf)
BramWerbrouck: numOfPins = 12 ????? and not 4?? because there are 4 items in the array??
There are six(!) items in the array, because you declared the array to have six integers! const int pins[6] is actually an array of six elements!
You only initialize four elements in the array, but that doesn't make a difference on the size of the array.
six integers, each 2 bytes in size, makes a total of 12 bytes in the array.
If I'd guess, you'd possibly wanted to code that:
const int pins[] = {5,6,7,8};
const int numOfPins = sizeof(pins)/sizeof(int);
In that code I leave the number of elements undeclared, it is actually defined by the numbers of initializing elements.
Then the number of elements is calculated: Number of bytes in the array divided by number of bytes in one element of the array.
@AWOL: spint doesn’t do the trick… :frowning:
BramWerbrouck: @AWOL: spint doesn't do the trick... :-(
No, I'm sure it doesn't, but sprintf will.
AWOL: but sprintf will.
Sorry, I hate autocorrect...
I meant that sprintf doesn't do the trick
Are you sure ? Show us what you tried.
byte addresses[][6] = {};
char cBuffer[10];
   sprintf(cBuffer,  "%dNode", i +1);
    addresses[i][6] = cBuffer;
I already pointed out that a six element array doesn't have an element with index six. Why don't you just sprintf direct into "addresses"?
I already pointed out that a six element array doesn't have an element with index six. It's not about the elements, but the value of the elements:
I expected this in the array addresses[][6] :
addresses[][6]= {"1Node","2Node","3Node","4Node"};
But I see this in the serial monitor (if I use Serial.println(addresses*[6])):* 205 205 205 205
OK, good luck with that approach. Let us know how you get on.
addresses*[6] = cBuffer; is not what you want*
addresses[i][6] =  (byte)atoi(cBuffer);
Serial.println(addresses[i][6]);
gives me :
1 2 3 4 5
gives me 50 51 52 0 254
Anyone???
Let me restate: a six element array has the following valid indices: 0,1,2,3,4,5.
You will notice that 6 does not appear in that sequence.
Why don't you sprintf directly into "addresses"?
Whatever you do, make certain that you're not writing to memory you don't own.
sprintf(addresses[i], "%dNode", i + 1);
and
Serial.println(addresses[i]);
ok I take pity…but think about these things:
why use char rather than byte for addresses?
if 9 becomes 10 or more, then 6 must become at least 7. why?
char addresses [9][6];
for (int ix = 0; ix < sizeof(addresses)/sizeof(addresses[0]); ix++)
   sprintf(addresses[ix],"%dNode",ix+1);
   Serial.println(addresses[ix]);
