Problems with SPI bus
Hi not sure if this is the correct place for this.
I am designing a sensor platform to measure airflow. I am using a LDES250U differential pressure sensor accessing it through the SPI bus which runs at 5MHz
Unfortunately when I run the code all I see is 0 from the sensor
I have attached my code and data sheet for the sensor and am hoping that someone can see where I am making the mistake
Thanks
Dave
DS_Standard-LDE_E_11815.pdf (203 KB)
Init_Frank_3_Query.ino (9.78 KB)
Take these out, the library takes care of them
#define DATAOUT 11 //MOSI
#define DATAIN 12 //MISO
#define SPICLOCK 13 //SCK
pinMode (SCL, INPUT_PULLUP);
pinMode (SDA, INPUT_PULLUP);
pinMode (DATAOUT, OUTPUT);
pinMode (DATAIN, INPUT);
pinMode (SPICLOCK, OUTPUT);
When does this pin get written HIGH again in setup() ?
Serial.print (F("Initialising SD card..."));
digitalWrite (chipSelect, LOW);
