Problems with ST7796S library on MEGA2560
Im trying to connect my 4.0'' TFT SPI 480x320 v1.0 display to mega (Ive used lvl shifters for needed pins) but when I try to upload code it gives following error:
C:\Users---------\Documents\Arduino\libraries\Adafruit_GFX_Library/Adafruit_SPITFT.h:252:23: error: no members matching 'Adafruit_GFX::drawRGBBitmap' in 'class Adafruit_GFX'
using Adafruit_GFX::drawRGBBitmap; // Check base class first
I have installed latestr version of Adafruit_GFX library and downloaded Adafruit_ST7796S_kbv from Davids github. The code Im using is example code for graphic test from that library:
  This is our library for the Adafruit HX8357D Breakout
  ----> http://www.adafruit.com/products/2050
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7796S_kbv.h>
// These are 'flexible' lines that can be changed
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8 // RST can be set to -1 if you tie it to Arduino's reset
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ST7796S_kbv tft = Adafruit_ST7796S_kbv(TFT_CS, TFT_DC, TFT_RST);
// SoftSPI - note that on some processors this might be *faster* than hardware SPI!
//Adafruit_ST7796S_kbv tft = Adafruit_ST7796S_kbv(TFT_CS, TFT_DC, MOSI, SCK, TFT_RST, MISO);
  Serial.println("ST7796S_kbv Test!");
  tft.begin();
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ST7796S_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ST7796S_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ST7796S_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ST7796S_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ST7796S_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Serial.println(F("Benchmark                Time (microseconds)"));
  tft.setRotation(1);
  Serial.print(F("Text                     "));
  Serial.println(testText());
  Serial.print(F("Lines                    "));
  Serial.println(testLines(ST7796S_CYAN));
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(ST7796S_GREEN));
  tft.fillScreen(ST7796S_BLACK);
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, ST7796S_RED));
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testText();
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(ST7796S_RED);
  tft.fillScreen(ST7796S_GREEN);
  tft.fillScreen(ST7796S_BLUE);
  tft.fillScreen(ST7796S_WHITE);
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(ST7796S_WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ST7796S_YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(ST7796S_RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(ST7796S_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
  tft.println(F("Alice was beginning to get very tired of sitting by her sister on the bank, and of having nothing to do: once or twice she had peeped into the book her sister was reading, but it had no pictures or conversations in it, 'and what is the use of a book,' thought Alice 'without pictures or conversations?'"));
tft.println(F("So she was considering in her own mind (as well as she could, for the hot day made her feel very sleepy and stupid), whether the pleasure of making a daisy-chain would be worth the trouble of getting up and picking the daisies, when suddenly a White Rabbit with pink eyes ran close by her."));
tft.println(F("There was nothing so very remarkable in that; nor did Alice think it so very much out of the way to hear the Rabbit say to itself, 'Oh dear! Oh dear! I shall be late!' (when she thought it over afterwards, it occurred to her that she ought to have wondered at this, but at the time it all seemed quite natural); but when the Rabbit actually took a watch out of its waistcoat-pocket, and looked at it, and then hurried on, Alice started to her feet, for it flashed across her mind that she had never before seen a rabbit with either a waistcoat-pocket, or a watch to take out of it, and burning with curiosity, she ran across the field after it, and fortunately was just in time to see it pop down a large rabbit-hole under the hedge."));
tft.println(F("In another moment down went Alice after it, never once considering how in the world she was to get out again."));
tft.println(F("The rabbit-hole went straight on like a tunnel for some way, and then dipped suddenly down, so suddenly that Alice had not a moment to think about stopping herself before she found herself falling down a very deep well."));
tft.println(F("Either the well was very deep, or she fell very slowly, for she had plenty of time as she went down to look about her and to wonder what was going to happen next. First, she tried to look down and make out what she was coming to, but it was too dark to see anything; then she looked at the sides of the well, and noticed that they were filled with cupboards and book-shelves; here and there she saw maps and pictures hung upon pegs. She took down a jar from one of the shelves as she passed; it was labelled 'ORANGE MARMALADE', but to her great disappointment it was empty: she did not like to drop the jar for fear of killing somebody, so managed to put it into one of the cupboards as she fell past it."));
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = tft.width(), h = tft.height();
  start = micros();
  for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = tft.width()  / 2,
                cy = tft.height() / 2;
  n     = min(tft.width(), tft.height());
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = tft.width()  / 2 - 1,
                cy = tft.height() / 2 - 1;
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx-i2, cy-i2, i, i, color1);
    t    += micros() - start;
    // Outlines are not included in timing results
    tft.drawRect(cx-i2, cy-i2, i, i, color2);
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
      tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                w = tft.width()  + radius,
                h = tft.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
      tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
  int           n, i, cx = tft.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      tft.color565(200, 20, i));
unsigned long testFilledTriangles() {
  int           i, cx = tft.width()  / 2 - 1,
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
    tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(0, i, i));
    tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(i, i, 0));
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
                cx = tft.width()  / 2 ,
                cy = tft.height() / 2 ;
  w     = min(tft.width(), tft.height());
  start = micros();
  for(i=0; i<w; i+=8) {
    i2 = i / 2 - 2;
    tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 100, 100));
unsigned long testFilledRoundRects() {
  int           i, i2,
                cx = tft.width()  / 2 + 10,
                cy = tft.height() / 2 + 10;
  start = micros();
  for(i=min(tft.width(), tft.height()) - 20; i>25; i-=6) {
    i2 = i / 2;
    tft.fillRoundRect(cx-i2, cy-i2, i-20, i-20, i/8, tft.color565(100, i/2, 100));
Please run the example(s) from the Adafruit_ST7796S_kbv GitHub.
Most importantly. Please report the Adafruit_GFX library version.
The simplest way is : enable verbose compilation in File->Preferences. Copy-paste the "used library" lines.
These show which library and where it resides on your PC.
David.
Yes, Adafruit_ST7796S_kbv is not working correctly with the current Adafruit_GFX, Adafruit_SPITFT for the spitftbitmap example
I am not sure why.
drawRGBBitmap() seems to work ok.
drawRGBBitmap() is an overloaded Adafruit_GFX method with four different signatures:
  void drawRGBBitmap(int16_t x, int16_t y, const uint16_t bitmap[], int16_t w,
                     int16_t h);
  void drawRGBBitmap(int16_t x, int16_t y, uint16_t *bitmap, int16_t w,
                     int16_t h);
                     const uint8_t mask[], int16_t w, int16_t h);
  void drawRGBBitmap(int16_t x, int16_t y, uint16_t *bitmap, uint8_t *mask,
Adafruit_ILI9341, Adafruit_ST7735, ... all inherit from Adafruit_SPITFT.
Adafruit_SPITFT replaces one of these methods with a hardware version of the SRAM method:
  void drawRGBBitmap(int16_t x, int16_t y, uint16_t *pcolors, int16_t w,
                     int16_t h);
This means that the SRAM version works fast but the other 3 versions rely on the original Adafruit_GFX implementaions. i.e. plot individual pixels which is very slow.
David.
Hi David, I finally decided to ask this maybe silly question: what does kbv stand for?
Google found knowledge-based view, and some abbreviations for German names.
But I assume it means something different. Maybe bv for board version, k for connected?
Thanks
Jean-Marc
Added:
My confusion has been resolved. The library Adafruit_ST7796S_kbv is from David.
_kbv is the appendix David uses. The only exception seem to be some library from LCDWIKI.
I got a personal message form David with hints for the origin of the kbv abbreviation. Thanks.
I am using Adafruit GFX v1.10.10 (checked it in library manager, should be newest version).
I have managed to upload graphictest code from your library Adafruit_ST7796S but it just gives me blank white screen.
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_ST7796S_kbv.h"
#define TFT_CS 10
#define TFT_DC 9
  tft.begin();
  tft.setRotation(1);
void loop(void) {
    testText();
  tft.println();
  tft.setTextSize(5);
  tft.setTextSize(2);
  tft.setTextSize(1);
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  x2    = w - 1;
  start = micros();
  int           n, i, i2,
  start = micros();
    i2 = i / 2;
  int           n, i, i2,
    i2    = i / 2;
    start = micros();
  return t;
  start = micros();
  start = micros();
  n     = min(cx, cy);
  start = micros();
    tft.drawTriangle(
  start = micros();
    start = micros();
  return t;
  int           w, i, i2,
  start = micros();
    i2 = i / 2 - 2;
  int           i, i2,
  start = micros();
    i2 = i / 2;
I am using Arduino MEGA to as microcontroller and logic level shifter hw221 and external power supply for lcd screen, my connections are as follows:
5V mega -> Vb of level shifter
3.3V mega -> Va of lvl shifter
GND mega -> GND power supply for common ground
Vcc LCD -> V+ power supply (5V)
Gnd LCD -> V- power supply (GND)
8 mega -> B2 logic shifter A2 -> RESET of LCD
9 mega -> B3 logic shifter A3 -> DC of LCD
10 mega -> B1 logic shifter A1 -> CS of LCD
50 mega -> B6 logic shifter A6 -> MISO of LCD
51 mega -> B4 logic shifter A4 -> MOSI of LCD
52 mega -> B5 logic shifter A5 -> SCK of LCD
OE shifter -> 3.3V for HIGH logic level
Thanks for your wiring description.
I built graphicstest.ino from the examples:
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino-1.8.13\hardware\arduino\avr\libraries\SPI
Using library Adafruit_GFX_Library at version 1.10.10 in folder: C:\Users\David Prentice\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_ST7796S_kbv at version 1.0.0 in folder: C:\Users\David Prentice\Documents\Arduino\libraries\Adafruit_ST7796S_kbv
Using library Adafruit_BusIO at version 1.7.3 in folder: C:\Users\David Prentice\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino-1.8.13\hardware\arduino\avr\libraries\Wire
"C:\\Users\\David Prentice\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\DAVIDP~1\\AppData\\Local\\Temp\\arduino_build_437681/graphicstest.ino.elf"
Sketch uses 20852 bytes (8%) of program storage space. Maximum is 253952 bytes.
Global variables use 726 bytes (8%) of dynamic memory, leaving 7466 bytes for local variables. Maximum is 8192 bytes.
It builds and runs on my Red ST7796S SPI display. I use 74HC4050 level shifters on 9, 10, 50, 52, (4, 6) and resistor divider for 8. (4, 6 are /SD_CS and /T_CS)
ST7796S_kbv Test!
Display Power Mode: 0x8C
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Self Diagnostic: 0xC0
Text                     1133340
Lines                    2957604
Rectangles (outline)     143664
Circles (outline)        1256372
Triangles (outline)      580016
Triangles (filled)       2958796
Rounded rects (outline)  331352
Rounded rects (filled)   4943328
Done!
So the "register reads" are not quite correct.
spitftlcd.ino compiles but does not display properly.
I can display monochrome bitmaps, BMP, JPG images on this display but need to solve the spitftlcd.ino problem.
I will add some other examples in the next day (or two).
David.
