Problems with Switch Case
Im having some problems using switch case, I have 2 cases.Case S and case A. i want them to run individually but for some reason when i enter S in serial monitor, it runs my S then runs my A. when i enter A it only runs A.
  int Outputs[] = {3,4,5,6,8};
  int pwmpin = 13;
  void four();
  void twelve();
  void twenty();
 pinMode (Outputs[0], OUTPUT);
 pinMode (Outputs[1], OUTPUT);
 pinMode (Outputs[2], OUTPUT);
 pinMode (Outputs[3], OUTPUT);
 pinMode (Outputs[4], OUTPUT);
 pinMode (pwmpin, OUTPUT);
  int x=0;
  int checker=1;
 char data = Serial.read();
  switch (data) {
    case 'S':
    Serial.println("Running DI");
    int x=0;
while(x<checker)
     digitalWrite(8, HIGH);
     delay(2000);
     digitalWrite(8, LOW);
     delay(10);
    Serial.println("X++");
        x++;
 Serial.write("Done");
case 'A':
    Serial.println("Running AI");
    four();
    delay(2000);
    twelve();
    delay(2000);
    twenty();
what's
wrong with
your
code
indentation?
I tried with dummy
void four() {}
void twelve() {}
void twenty() {}
functions as you did not provide them and for me it works and only run one or the other.
that being said, if your functions rely on the value of the global variable x to be changed in the 'S' case, then you have a problem because you are redefining that variable as a local scope one within your S case.
case 'S':
[color=red]        int x = 0;
[/color]        while (x < checker) {
