problems with synchronization of arduino and chronodot
I am using a arduino-1 and chronodot to control indipendently 3 different LEDs strips.
I connected the arduino-1 to chronodot as indicated in this link: http://zevenrodriguez.com/chronodot-and-arduino-1-0/
Then, I connected the 3 different LEDs to 3 different digital pins (9, 10 ,11) as indicated in this link: bildr High-Power Control: Arduino + TIP120 Transistor - bildr
I can set and read correctly the time on the serial port COM4.
As a first step, I am controlling the light ON and OFF only of the LED connected to pin 11 with TimeAlarms, and I set the intensity of the LEDs connected to pin 9 and 10 with analogWrite().
This is the sketch:
#include <Time.h>                  // include the library Time
#include <TimeAlarms.h>            // include the library TimeAlarms
  Serial.begin(9600);     // initialize the serial port
  setTime(8,30,0,1,1,11); // set actual time and date   (hours,minute, seconds, day, month, year)
  Alarm.alarmRepeat(9,0,0, MorningAlarm);  // create a first alarm to do an action every day at the same time
  Alarm.alarmRepeat(18,0,0, EveningAlarm);  // create a second alarm to do an action every day at the same time
void  loop(){
  digitalClockDisplay(); //declare the function digital clock display
  Alarm.delay(1000); // wait one second between clock display (it is necessary to allow the alarms to work properly)
  int irLed = 9;     // declare that we have connected the Infrared LEDs to pin 9
  int redLed = 10;    // declare that we have connected the Red LEDs to pin 10
  analogWrite(irLed, 250);    // Switch on Infrared LEDs at the intensity (we can use values in the following range 0-250)
  analogWrite(redLed, 250);   // Switch on Red LEDs at the intensity (we can use values in the following range 0-250)
void MorningAlarm(){         // functions to be called when the first alarm triggers
  int whiteLed = 11;          // declare that we have connected the White LEDs to pin 11
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {       // sets the value (range from 0 to 255):
  analogWrite(whiteLed, fadeValue);    // start to fade in the LEDs
  delay(1000);                  // wait for 1 second to see the dimming effect
   Serial.println("LIGHT ON");       // write on the serial port "LIGHT ON"
void EveningAlarm(){         // functions to be called when the first alarm triggers
  int whiteLed = 11;
  for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
  delay(300);
  Serial.println("LIGHT OFF");        // the same as above but with fade out
void digitalClockDisplay()
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.println();          // digital clock display of the time on serial port
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);      // definitions of the format to write the time
}                            // END
I FOUND THE FOLLOWING PROBLEM:
  • after 10 days that arduino is running and controlling the light ON/OFF of the LEDs connected to the pin 11, I realized that there is a delay of 8 minutes (in the time printed in the serial port) accumulated in these 10 days. Consequently there is a delay in triggering the ON/OFF of the light (pin 11).
How is it possible with chronodot?
Is there something wrong in my sketch?
I really appreciate if someone could help me to find the solution.
Thank you
You don't put code in quote tags - you put them in code tags - How to post code properly
Pete
done. Sorry!
V
I don't see where you are actually using the Chronodot time. I think the Time library uses the Arduino's timer interrupt.
Pete
So the problem is at the beginning of the sketch when I set the time?
could you suggest me how is the best way to solve the problem?
Thank you
Valerio
Because you aren't using it?
The page you linked to has a link to the Adafruit RTC library ( GitHub - adafruit/RTClib: A fork of Jeelab's fantastic RTC Arduino library ) which you are not using.
Ok, thank you. :grin: :grin:
I will include the RTC library and modify the script.
I will write if everything will be OK.
Thank you
I modified my sketch and now I am usign the time from chronodot.
However, the alarms I created (Alarm.alarmRepeat and Alarm.alarmRepeat) do not trigger the actions I want to.
Do you see something wrong in the sketch?
Thank you for your help and sorry for some stupid errors…
Valerio
#include <Wire.h>
#include <Chronodot.h>             // include the library Chronodot
Chronodot RTC;
  Serial.println("Initializing Chronodot.");
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning()) {
  Serial.println("RTC is NOT running!");      // following line sets the RTC to the date & time this sketch was compiled
  RTC.adjust(DateTime(2013,12,2,8,0,0));
void  loop(){
  for(int fadeValue = 0 ; fadeValue <= 75; fadeValue +=5) {       // sets the value (range from 0 to 255):
  int whiteLed = 11;
  for(int fadeValue = 75 ; fadeValue >= 0; fadeValue -=5) {
  DateTime now = RTC.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    if(now.month() < 10) Serial.print("0");
    Serial.print(now.month(), DEC);
    Serial.print('/');
    if(now.day() < 10) Serial.print("0");
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    if(now.hour() < 10) Serial.print("0");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    if(now.minute() < 10) Serial.print("0");
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    if(now.second() < 10) Serial.print("0");
    Serial.print(now.second(), DEC);
    delay(5000);
}                            // END
