I figured it was some sort of memory problem. I'm pretty sure I'm not stepping on anything, i've done this several times. How robust is the memory management for the arduino.
I simplified the code. I wrote a string class that used malloc to manage the string memory. I got rid of this code and do it all now with local variables, also reduced the amount of data written, and it works better, but still hangs after a while. Here's the code if anyone wants to look at it.
#include <Client.h>
#include <Ethernet.h>
#define SERVER_PORT 14822
#define NUMBER_SAMPLES 8
#define roomId 1
#define boardId 1
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 200, 200 };
byte gateway[] = { 192, 168, 200, 1 };
byte netmask[] = { 255, 255, 255, 0 };
byte server[] = { 192, 168, 200, 110 };
int reportInterval = 60; // temperature readings interval in seconds.
unsigned long startTime = 0;
unsigned long minuteTimer = 0;
#define NO_SENSOR 0
#define SENSOR_TEMP 1
#define SENSOR_LIGHT 2
#define NUMBER_SENSORS 6
int sensors[NUMBER_SENSORS];
void
ConvertInt(char *data, int value, int size)
int length;
if ( size == 0 )
if ( value == 0 )
length = 1;
int newvalue = value;
length = 0;
while ( newvalue > 0 )
newvalue /= 10;
length++;
length = size;
for ( int i = 0; i < length; i++ )
int mod = value % 10;
data[length - i - 1] = (char)mod + '0';
value = value / 10;
data[length] = '\0';
int
ConvertDouble( char *data, double value, int decimalPlaces)
char wholeString[10];
char fractionString[10];
ConvertInt(wholeString, (int)value, 0);
double dec = value - (double)((int)value);
for ( int i = 0; i < decimalPlaces; i++ )
dec = dec * 10.0;
ConvertInt(fractionString, (int)dec, decimalPlaces);
int n = 0;
for (n = 0; n < wholeString[n] != '\0'; n++)
data[n] = wholeString[n];
data[n++] = '.';
for (int i = 0; fractionString != '\0'; i++)
_ data[n++] = fractionString*;_
_ data[n] = '\0';_
_}_
double ReadValue( int sensorId )
_{_
_ double value = 0.0;_
_ //_
_ // Read a number of samples and average them to get a more accurate value._
_ //_
for (int i = 0; i < NUMBER_SAMPLES; i++)
_ value += (double)analogRead(sensorId);_
value = value / (double)NUMBER_SAMPLES;
_ return value;_
_}_
double
ReadTemp(int sensorId)
_{_
_ double tempc = ReadValue(sensorId);_
_ // The temperate is 10mv per degree, 1024 is 5.0V, so scale this to degress._
_ tempc = ( 5.0 * tempc * 100.0) / 1024.0;_
_ //_
_ // Convert to Fahrenheit*_
_ return ((tempc * 9.0)/5.0) + 32.0;_
void
WriteMessageHeader(Print *stream )
// stream->println("<?xml version=\"1.0\" encoding=\"utf-8\" ?>");
// stream->println("<Message");
// stream->println(" xmlns="urn:sol.bosque.com:Solar:Arduino"");
// stream->println(" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance\"");
// stream->print(" xsi:schemaLocation="urn:sol.bosque.com:Solar:Arduino");
// stream->println(" http://winserv/Schemas/ArduinoData.xsd\">");
* stream->println("<?xml version=\"1.0\"?>");*
* stream->println("");*
void
WriteMessageEnd(Print *stream)
* stream->println("</?xml>");*
void
WriteLocation(Print *stream, int sensorId)
* stream->print(" \n");*
* stream->print(" ");*
* stream->print(roomId);*
* stream->print("\n");*
* stream->print(boardId);*
* stream->print(sensorId);*
void WriteLight(Print *stream, int id)
* int time = (millis() - startTime)/1000;*
* WriteMessageHeader(stream);*
* stream->print((int)ReadValue(id));*
* stream->print(time);*
* stream->println(" Light");*
* WriteLocation(stream, id);*
* WriteMessageEnd(stream);*
void WriteTemperature(Print *stream, int id)
* double temp = ReadTemp(id);*
* stream->print( " "); *
* char s[20];*
* ConvertDouble(s, temp, 2);*
* stream->print(s);*
* stream->print("\n F\n ");*
_ stream->print((int)(temp100.0));_
_ stream->print("\n");_
_ stream->println(" Temperature");_
_ WriteLocation(stream, id);_
_ stream->print(" \n");_
_ WriteMessageEnd(stream);_
_}_
void WriteSensors()
_{_
Client client( server, SERVER_PORT);
_ int connected = 0;_
_ if (client.connect() != 0)_
_ {_
_ connected = 1;_
_ }_
for ( int i = 0; i < NUMBER_SENSORS; i++)
_ {_
_ switch ( sensors )
{_
case SENSOR_TEMP:
_// WriteTemperature(&Serial, i);
if (connected == 1)
WriteTemperature(&client, i);
break;_
case SENSOR_LIGHT:
_// WriteLight( &Serial, i);
if (connected == 1)
WriteLight(&client, i);
default:
delay(10);
if (connected == 1)
client.stop();
}*_
* Serial.begin(115200);*
* Ethernet.begin( mac, ip, gateway, netmask );*
* startTime = millis();*
* minuteTimer = millis();*
// for (int n=0; n < 5; n++)
// command[n] = '\0';
* for ( int i = 0; i < NUMBER_SENSORS; i++)
_ {
sensors = NO_SENSOR;
}_
sensors[1] = SENSOR_TEMP;
// sensors[2] = SENSOR_TEMP;
// sensors[3] = SESNOR_TEMP;
sensors[5] = SENSOR_LIGHT;
_ WriteSensors();
unsigned long delta = ( millis() - minuteTimer ) / 1000;
if ( delta > reportInterval )
WriteSensors();
// checkSerial();
}*_
