Hi, i just started with Arduino and i have a Little Problem with programming sth. for School.
My Task is to use the HC-SR04 ultrasonic sensor and the piezo-Speaker. I have to make sure that if a ball comes Closer than 8cm to the sensor, it gives 2 different tones with a Little delay between them.
The Problem I have is with the twoe different tones and the delay.
can anyone pleeeeeeeeease help me . I´m sitting on it for 2 Hours already and i´m running out of time. I hope someone can help me. I´m adding the Code I have already.
int trigger=7;
int echo=6;
long dauer=0;
long entfernung=0;
int piezo=5;
Serial.begin (9600);
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
pinMode(piezo, OUTPUT);
digitalWrite(trigger, LOW);
delay(5);
digitalWrite(trigger, HIGH);
delay(10);
dauer = pulseIn(echo, HIGH);
entfernung = (dauer/2) * 0.03432;
if (distance >= 500 || distance <= 0)
Serial.println;
Serial.print;
Serial.println(" cm");
if (entfernung <= 80)
digitalWrite(piezo,HIGH);
digitalWrite(piezo,LOW);
What exactly is the problem ?
What do think that these 2 lines of code do ?
Serial.println;
Serial.print;
Does the code actually compile ?
Hi UKHeliBob,
I appreciate a lot that you try to help me with this.
The Problem is that i Need to get the piezo Speaker to Play just two tones with a delay between it (1sec) , IF the ball Comes for 10 seconds Closer than 8cm to the sensor.
I hope I expressed myself in a more understandable way now (;
ChiefMarco:
You don't have a variable named 'distance' but you try to use it. Remove the lines that use 'distance'.
If you want two different notes you will probably have to use a piezo speaker and the tone() function.
Hi John,
I actually use a piezo Speaker i´m just incapable of finding out the way that it Plays just 2 different tones with a delay between it.
How should I use the tone function because I´ve tried it already and it Shows Always some Errors.
By the way,
thanks for helping John
Please post what you tried and the full error messages
so this is what i typed in:
int trigger=7;
int echo=6;
long dauer=0;
long entfernung=0;
int piezo=5;
delay(5);
delay(10);
distance = pulseIn(echo, HIGH);
distance = (dauer/2) * 0.03432;
if (distance >= 500 || entfernung <= 0)
Serial.println(“80”);
Serial.print(distance);
Serial.println(" 80cm");
if (distance <= 80)
digitalWrite();
tone(8, 100);
noTone(8);
tone(8, 200)
and that´s the Errors:
In function ‘void loop()’:
33:1: error: ‘distance’ was not declared in this scope
58:14: error: too few arguments to function ‘void digitalWrite(uint8_t, uint8_t)’
1:0:
126:6: note: declared here
64:1: error: expected ‘;’ before ‘}’ token
66:1: error: expected ‘}’ before ‘else’
So where is distance declared ? Answer : nowhere
digitalWrite();
Which pin do you want to write to and what value (HIGH or LOW) do you want to write ?
tone(8, 200)
No semicolon on the end of the line
if (distance <= 80)
digitalWrite();
tone(8, 100);
noTone(8);
tone(8, 200)
Which commands should be executed if the test returns true and which will always be executed ? HINT : put the { and } round the conditional code
On a more general note, you did not Auto Format the code in the IDE or use code tags when posting it so it is hard to follow and even has a smiley in it. Please read this before posting a programming question and follow the advice it contains
ChiefMarco:
Perhaps reading the reference material in your native language would help:
https://www.arduino.cc/reference/de/language/functions/advanced-io/tone/
