I have a Problem regarding the usage of the JLED Library with an Arduino NANO. The example program (LED breathing) works fine with my Hardware.
In a second step i tried to connect a switch to my Arduino Nano. With this switch I want to start and stop the "breathing effect". But I cant get this working.
Unfortunately I'm still a beginner regarding programming. Maybe one of you can help me. Thanks in advance.
Here my code:
#include <jled.h>
const int Switch = 7;
auto led = JLed(9);
pinMode(Switch, INPUT_PULLUP);
led.Update();
if (digitalRead(Switch) == LOW){
led.Breathe(2000).DelayAfter(1000).Forever();
else{
led.Stop();
Do as I suggested and print the value returned by digitalRead()
This
leads me to believe that there will be at least 3 seconds between each digitalRead()
If you are aiming to use the switch as an on/off toggle for the effect then you are doing ig incorrectly. If, however, you want the effect only to run when the button is held down then it could work. Which is it ?
led.Update();
if (led.IsRunning() == false) //start again only if the sequence is not currently running
led.Breathe(2000).DelayAfter(1000);
led.Stop();
thank you very much. Your code works fine. Now I added a second switch to start different effects. Each of the two if-loops works fine.
But they don`t work together. Any Idea? Thanks in advance!
#include <jled.h>
const int SwitchA = 7;
const int SwitchB = 6;
auto led = JLed(9);
int ledpin=9;
pinMode(SwitchA, INPUT_PULLUP);
pinMode(SwitchB, INPUT_PULLUP);
led.Update();
if (digitalRead(SwitchA) == LOW && digitalRead(SwitchB) == HIGH)
led.Stop();
if (digitalRead(SwitchA) == HIGH && digitalRead(SwitchB) == LOW)
led.FadeOn(2000).DelayBefore(500);
led.Stop();
led.Update();
else if (digitalRead(SwitchA) == HIGH && digitalRead(SwitchB) == LOW)
led.Stop();
Your code was always falling through to one or other of the led.Stop() calls
Ok understand and I tried your code and it works fine.
Now I want that the "else if" Argument executed only one time per toggle of switchB
Can I realize this with an variable in the loop which is reset in/outside the loop or is there a better way to realize this?
You need to detect when the button changes state rather than its current state. There is an example of this in the IDE. Look at the StateChangeDetection example
#include <jled.h>
auto led = JLed(9);
int ledpin=9;
int SWB_old = 1;
int SWB_state = 1;
//static boolean Durchlauf = true;
led.Update();
led.Breathe(5000).Forever();
delay (200);
SWB_state = digitalRead(SwitchB);
if (led.IsRunning() == false && SWB_state != SWB_old) //start again only if the sequence is not currently running
led.FadeOn(5000).Repeat(1);
SWB_old = SWB_state;
led.Stop();
//https://forum.arduino.cc/index.php?topic=671518.0
#include <jled.h>
auto led = JLed(9);
int ledpin = 9;
led.Stop();
led.Update();
byte stateA = digitalRead(SwitchA);
byte stateB = digitalRead(SwitchB);
if (stateA == LOW && stateB == HIGH)
else if (stateA == HIGH)
if (stateB == LOW)
led.Stop();
The digitalRead()s are only done once and only then if the led sequence is not running. I have split the second input test into two stages rather than having a compound test to make it easier to change the code to detect the input becoming LOW
As you have got it working feel free to ignore the suggested changes
Ok.....now i added the third and the last switch to my code.....!
Now it looks like this and its working! Thank you for your great help. In the next step I try to clean up the code a bit.......
#include <jled.h>
const int SwitchC = 5;
auto led = JLed(9);
int ledpin=9;
int SWB_old = 1;
int SWB_state = 1;
pinMode(SwitchC, INPUT_PULLUP);
led.Update();
if (digitalRead(SwitchA) == LOW && digitalRead(SwitchB) == HIGH && digitalRead(SwitchC) == HIGH)
else if (digitalRead(SwitchA) == HIGH && digitalRead(SwitchB) == HIGH && digitalRead(SwitchC) == LOW)
led.Blink(1000, 1000).Forever();
else if (digitalRead(SwitchA) == HIGH && digitalRead(SwitchB) == LOW && digitalRead(SwitchC) == HIGH)
delay (200);
led.FadeOn(10000).Repeat(1);
led.Stop();
The process is very familiar to me from working with customers
Customer says "I want the program to do this"
The program is written, delivered and tested
Customer says "I have had another idea"
The revised program is written and delivered and tested
Customer says "That's great, but can you just add ..."
The program now requires a rewrite and would have been written in a different way in the first place if the full specification had been known at the start.
The program is rewritten, delivered and the customer says "Why is the project running late ?"
In the commercial world we often spent as much time finalising the specification as we did writing the program and the customer was expected to sign off the specification and pay heavily for later changes, so it was not always bad news for the software house and programs would often be written with future possible changes in mind.
