Hi, I'm doing a project with the Arduino YUN or Arduino micro (I'm still experimenting with both), and the humidity sensor SKU: SEN0114,
I expect that somebody can help me, with the sampler code.
Example code for the moisture sensor
Editor: Lauren
Date: 13.01.2012
Version: 1.0
Connect the sensor to the A0 (Analog 0) pin on the Arduino board
The sensor value description
0 ~ 300 dry soil
300 ~ 700 humid soil
700 ~ 950 in water
void setup () {
Serial.begin (57600);
void loop () {
Serial.print ("Moisture Sensor Value");
Serial.println (analogRead (A0));
delay (100);
This is the sampler code I'm using to play with the moisture sensor, which is that they have give me on the web where I bought the sensor,
Proving it with different soils, and the monitor give me range of values from 400 to 700, and in theory would have to go from 0 to 1000, if I can help with this would be very grateful!
A greeting !
