First of all, sorry if my grammar is bad, or I make errors typing. I will try to do it the best I can.
I am new in the forum and Arduino itself, I started a few months ago building my first circuits and I´ve never had this problem before. I wanna try this sensor because is corrosion resistant and i live in a city with hight percentage of humidity in air so it´s easy to get corrosion in the standard humidity and temperature sensors.
when I try to print the measures using the tutorial on this page :
In your code Serial.begin(38400) sets the baud rate you are using, you need to set the the baud rate in the serial monitor to the same rate. This is the number in the lower right hand side of the serial monitor window. This needs to be set to 38400.
You can't have a negitave value for humidity so your sensor is not wired up correctly or the wires are not making contact. Pushing multi stranded wire in a solderless breadboard is not exactly robust.
