Problems with the Upload
Hi guys,
I have some problems while upoading any project on my arduino nano. I already checked up some typical errors of beginners. To sum up, I can't find the mistake. The last error message is this one:
Beim Hochladen des Sketches ist ein Fehler aufgetreten
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x04
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x04
Hope you can help me,
Mecanix
(deleted)
There's no option for an old bootloader if you're using an arduino uno though...
(deleted)
I cannot upload a program,can you help?
Showing the following error.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ANONYM~1\AppData\Local\Temp\arduino_build_715823/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.13s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\ANONYM~1\AppData\Local\Temp\arduino_build_715823/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\ANONYM~1\AppData\Local\Temp\arduino_build_715823/Blink.ino.hex:
avrdude: input file C:\Users\ANONYM~1\AppData\Local\Temp\arduino_build_715823/Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | #####################################An error occurred while uploading the sketch
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x62 != 0x0c
avrdude: verification error; content mismatch
avrdude done. Thank you.
