Problems with the use of the sketch Frequency timer by Nick Gammon
Hi!
I had a problem with using a sketch Gammon Forum : Electronics : Microprocessors : Timers and counters "Another frequency counter
// Frequency timer
// Author: Nick Gammon
// Date: 10th February 2012"
to measure the time of the pulse. I assembled the oscillator with a quadrature signal output at 328p. See below:
int tim=18;
  pinMode(5, OUTPUT);          // A
  pinMode(6, OUTPUT);          // B
  tim = 18;
 noInterrupts ();  // protected code
  digitalWrite(6, HIGH);
  delayMicroseconds (tim) ;
  digitalWrite(5, HIGH);
  digitalWrite(6, LOW);
  digitalWrite(5, LOW);
The problem lies in the fact that if you reduce the delay from 500 to 100-50 ms, then on the serial console, sometimes elapsedTime have about 4500000000 jumps, approximately equal to the maximum value for unsigned long .
// Frequency timer
// Input: Pin D2
volatile boolean first;
volatile boolean triggered;
volatile unsigned long overflowCount;
volatile unsigned long startTime;
volatile unsigned long finishTime;
// here on rising edge
void isr ()
  unsigned int counter = TCNT1;  // quickly save it
     // wait until we noticed last one
  if (triggered)
    return;
  if (first)
    startTime = (overflowCount << 16) + counter;
    first = false;
    return;
  finishTime = (overflowCount << 16) + counter;
  triggered = true;
  detachInterrupt(0);
}  // end of isr
// timer overflows (every 65536 counts)
ISR (TIMER1_OVF_vect)
  overflowCount++;
}  // end of TIMER1_OVF_vect
void prepareForInterrupts ()
  // get ready for next time
  EIFR = bit (INTF0);  // clear flag for interrupt 0
  first = true;
  triggered = false;  // re-arm for next time
  attachInterrupt(0, isr, RISING);
  }  // end of prepareForInterrupts
void setup ()
    pinMode( 13, OUTPUT);   //test
 // Serial.begin(57600);
 // Serial.println("Frequency Counter");
  // reset Timer 1
  TCCR1A = 0;
  TCCR1B = 0;
  // Timer 1 - interrupt on overflow
  TIMSK1 = bit (TOIE1);   // enable Timer1 Interrupt
  // zero it
  TCNT1 = 0;
  overflowCount = 0;
  // start Timer 1
  TCCR1B =  bit (CS10);  //  no prescaling
  // set up for interrupts
  prepareForInterrupts ();
  } // end of setup
void loop ()
  if (!triggered)
    return;
  unsigned long elapsedTime = finishTime - startTime;
  if ((elapsedTime<=1400)||(elapsedTime>=1600))
  {digitalWrite(13, HIGH);}
  //Serial.print (elapsedTime);
  // so we can read it
  delay (50);
 digitalWrite(13, LOW);
}   // end of loop
I assumed that this is somehow related to the transfer of data on the serial port. Therefore, I disabled this transmission and inserted a test of the time value with LED (the generator produces signal approximately = 1500). The result remains the same - LED sometimes flashes. What is the reason for this? Can the generator lose impulses?Maybe this is due to some requests from Bootloader? Or problems in the measurement program?
Thank you!
