Thats my problem I didn´t used thath library but there is still this fault:
#include <PubSubClient.h>
#include <SPI.h>
#include <WiFi101.h>
#define DHTPIN 2 // DHT Sensor connected to digital pin 2.
#define DHTTYPE DHT11 // Type of DHT sensor.
#define LIGHTPIN A0 // Analog light sensor connected to analog pin A0.
char ssid[] = "xxx"; // Change this to your network SSID (name).
char pass[] = "xxx#"; // Change this your network password
char mqttUserName[] = "xx_xx_x"; // Can be any name.
char mqttPass[] = "xx"; // Change this your MQTT API Key from Account > MyProfile.
char writeAPIKey[] = "xx"; // Change to your channel Write API Key.
long channelID = xx;
static const char alphanum[] ="0123456789"
"ABCDEFGHIJKLMNOPQRSTUVWXYZ"
"abcdefghijklmnopqrstuvwxyz"; // For random generation of client ID.
WiFiClient client; // Initialize the Wifi client library.
// DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor.
PubSubClient mqttClient(client); // Initialize the PuBSubClient library.
const char* server = "mqtt.thingspeak.com";
unsigned long lastConnectionTime = 0;
const unsigned long postingInterval = 20L * 1000L; // Post data every 20 seconds.
int status = WL_IDLE_STATUS; // Set a temporary WiFi status.
// Attempt to connect to WiFi network
while (status != WL_CONNECTED)
status = WiFi.begin(ssid, pass); // Connect to WPA/WPA2 Wi-Fi network.
delay(5000);
Serial.println("Connected to wifi");
mqttClient.setServer(server, 1883); // Set the MQTT broker details.
// Reconnect if MQTT client is not connected.
if (!mqttClient.connected())
reconnect();
mqttClient.loop(); // Call the loop continuously to establish connection to the server.
// If interval time has passed since the last connection, Publish data to ThingSpeak
if (millis() - lastConnectionTime > postingInterval)
mqttpublish();
void reconnect()
char clientID[10];
// Loop until we're reconnected
while (!mqttClient.connected())
Serial.print("Attempting MQTT connection...");
// Generate ClientID
for (int i = 0; i < 8; i++) {
clientID = alphanum[random(51)];
// Connect to the MQTT broker*
if (mqttClient.connect(clientID,mqttUserName,mqttPass))*
Serial.println("connected");*
} else*
Serial.print("failed, rc=");*
// Print to know why the connection failed.*
// See Arduino Client for MQTT for the failure code explanation.*
Serial.print(mqttClient.state());*
Serial.println(" try again in 5 seconds");*
delay(5000);*
// Use this function instead to publish to a single field directly. Don't forget to comment out the above version.
void mqttpublish() {
float t = 5; // Read temperature from DHT sensor.*
String data = String(t, DEC);*
int length = data.length();*
char msgBuffer[length];*
data.toCharArray(msgBuffer,length+1);*
Serial.println(msgBuffer);*
// Create a topic string and publish data to ThingSpeak channel feed.*
String topicString ="channels/" + String( channelID ) + "/publish/"+String(writeAPIKey);*
length=topicString.length();*
char topicBuffer[length];*
topicString.toCharArray(topicBuffer,length+1);*
mqttClient.publish( topicBuffer, msgBuffer );*
lastConnectionTime = millis();*
