Problems with timer
Hey guys,
I have the problem that I have to detect the speed signal of a fan (with the functions pulseIn and pulseOut) and I also want to generate a PWM signal. For this I need 2 different timers because otherwise they will interfere each other. How can I change this or how can I find out which timer is conected to which pin or to which function.
Thanks for your help!
Just use pulseIn/pulseOut and use PWM, you don't need to worry about hardware timers...
But it doesn´t work. It only works if I have the speed detection or the PWM Output. Maybe my code is wrong:
pinMode(10, OUTPUT); pinMode(3, INPUT); }
int Htime; //integer for storing high time int Ltime; //integer for storing low time float restime; // Htime+Ltime float frequency;
Htime=pulseIn(3,HIGH); //read high time Ltime=pulseIn(3,LOW); //read low time
restime = Htime + Ltime; frequency = 1000000/restime; // frequency fan
analogWrite(10, 150); // PWM Output
Serial.println(frequency); }
Your code runs as intended when I test it. I jumper pin 3 to pin 10, and see a constant print out of a frequency close to the default frequency(490Hz) of Timer1 which controls PWM on pin 10.
Please learn how to post code using the code tags </> so that is appears like this
  pinMode(3, INPUT);
float frequency;
  Htime = pulseIn(3, HIGH);   //read high time
  Ltime = pulseIn(3, LOW);    //read low time
  frequency = 1000000 / restime;   // frequency fan
Please elaborate on this statement... What do you define as "works" and what do you define as "doesn't work" because simply saying it doesn't work tells me nothing as to what is wrong with it.
