My program is supposed to make my buzzer sound a tone whenever my ultrasonic sensor detects an object less than 5 cm away for more than 5 seconds. However, i’m having difficulties getting the program to run consistently. After fulfilling my requirement the first time, the timing of it all gets messed up. I’m new to programming so any help would be much appreciated.
this is my program:
unsigned long delaystart = 0;
unsigned long delaytime = 5000;
int trigPin = 22 ; // Trigger
int echoPin = 23; // Echo
float duration, cm; // Ultrasonic sensor measurements
int buzzer = 12 ; //buzzer to arduino pin 12
pinMode(trigPin, OUTPUT); //ultrasonic sensor
pinMode(echoPin, INPUT); //ultrasonic sensor
pinMode(buzzer, OUTPUT);
delaystart = millis();
void loop(){
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
cm = ((duration/2) / 29.1);
if(cm>=5)
noTone(buzzer);
if(cm<5)
if((millis() - delaystart) >= delaytime)
delaystart += (delaytime);
tone(buzzer, 500);
