Problems with trigger input code
Oops. Found my error in this code. It was only doing what I told it to do. This fixed it:
void pinD19Interrupt()
  digitalWrite(pinD12, pinD12State);
  pinD12State = !pinD12State;
Now pinD12 toggles on every falling edge interrupt. Now back to troubleshooting the code with the trigger wheel.
These microprocessors can be so annoying.
a7
Probably the only thing more annoying than the microprocessor is the moron that is trying to program it.
I believe I've found the error of my ways. The revised program below works as it should. Now I can take that and try to troubleshoot the main program I'm working on.
Thanks again to all for the suggestions, it really helps to know I'm not completely alone.
// Program constants:
const byte pinD12 = 12;    // Output on pin D12, PB6, Output Compare 1B
const byte pinD11 = 11;    // Output on pin D11, PB5, Output Compare 1A
const byte pinD7 = 7;      // Output on pin D7, PH4, Output Compare 4B
const byte pinD6 = 6;      // Output on pin D6, PH3, Output Compare 4A
const byte pinD5 = 5;      // Output on pin D5, PE3, Output Compare 3A
const byte pinD19 = 19;    // ISR input on pin D19, INT2
const byte pinD45 = 45;    // Output on pin D45, PL4
const byte pinD49 = 49;    // Output on pin D49, PL0 (Debug output)
// Program variables:
volatile bool ckpFlag;                       // Flag to tell the main loop that we have just had falling edge on pin 19
volatile unsigned int iteration;
volatile unsigned long curTimeStampUS;       // Current microsecond time stamp
volatile unsigned long prevTimeStampUS;      // Previous microsecond time stamp
volatile unsigned long curToothPeriod;       // Period between time stamps
volatile unsigned long prevToothPeriod;      // Previous period between time stamps
volatile bool periodOKFlag;                  // Flag to indicate that the interrupt period is great enough not to be noise and short enough that
                                             // calculations that us the period can be doen without overflow
volatile byte pinD49State;                   // Debug output state
  iteration++;
  ckpFlag = true;
  pinMode(pinD12, OUTPUT);         // Declare  pinD12 an output
  digitalWrite(pinD12, LOW);       // Initialize pinD12 LOW
  pinMode(pinD11, OUTPUT);         // Declare  pinD11 an output
  digitalWrite(pinD11, LOW);       // Initialize pinD11 LOW
  pinMode(pinD7, OUTPUT);          // Declare  pinD7 an output
  digitalWrite(pinD7, LOW);        // Initialize pinD7 LOW
  pinMode(pinD6, OUTPUT);          // Declare  pinD6 an output
  digitalWrite(pinD6, LOW);        // Initialize pinD6 LOW
  pinMode(pinD5, OUTPUT);          // Declare  pinD5 an output
  digitalWrite(pinD5, LOW);        // Initialize pinD5 LOW
  pinMode(pinD45, OUTPUT);         // Declare  pinD45 an output
  digitalWrite(pinD45, LOW);       // Initialize pinD45 LOW
  pinMode(pinD49, OUTPUT);         // Declare  pinD49 an output
  digitalWrite(pinD49, LOW);       // Initialize pinD49 LOW
  attachInterrupt(digitalPinToInterrupt(pinD19), pinD19Interrupt, FALLING); // Attach pinD19 to pinD19 Interrupt() ISR function, interrupt on falling edge
  Serial.begin(115200);            // Initialize serial communication at 115200 bits per second(for program developement)
  ckpFlag = false;
  iteration = 0;
  periodOKFlag = false;
  pinD49State = LOW;
  if(ckpFlag == true)
//    Serial.println(iteration); // (For program developement)
    curTimeStampUS = micros();                         // Get the current microsecond time stamp
    curToothPeriod = curTimeStampUS - prevTimeStampUS; // Tooth period = current time stamp minus the previous one
    prevToothPeriod = curToothPeriod;                  // Save the current tooth period as the previous tooth period
    prevTimeStampUS = curTimeStampUS;                  // Save the current time stamp as the previous time stamp
    if(periodOKFlag == false)
     if((curToothPeriod > 35000) && (curToothPeriod< 40000))
        periodOKFlag = true;
      } // End of if((curToothPeriod > 35000) && (curToothPeriod< 40000))
        ckpFlag = false;
    } // End of if(periodOKFlag == false)
    if(periodOKFlag == true)
        digitalWrite(pinD12, HIGH);
        pinD49State = !pinD49State;            // Toggle pinD49State
        digitalWrite(pinD49, pinD49State);     // Copy pinD49State to pinD49
        ckpFlag = false;
      } // End of if(periodOKFlag == true)
    } // End of if(ckpFlag == true)
} // End of void loop()
