hello,
i have got some problems with my Robot Project
Hardware:
Arduino Nano,
US Sensor x1,
IR Sensor x1,
L298N x2 ( each per motor)
HC-05 BT Modul,
1st problem:
in serial monitor and in android bluetooth app it shows the measured distance, but to fast, i want only 1-4 times the result in a second.
2nd:
i don't get it working to conntroll my switch case with the us sensor.
if the distance is <10 i want to "stop" the motors and change direction to "left" or "right" but only a short time that the robot only makes 45-120 Degree ( depending on the speed)
and after changing direction it should drive forwards again.
here is my code
//---------------L298N Motoren----------------------------
// connect motor controller pins to Arduino digital pins
// motor one
int enA = 5;
int in1 = 7;
int in2 = 8;
// motor two
int enB = 6;
int in3 = 9;
int in4 = 10;
int motorspeed;
int i = 56; //bei 0 -55 nur fiepsen
int HindernisIR1 = 0;
int HindernisIR2 = 0;
int HindernisIR3 = 0;
int HindernisUS = 0;
int switchvar;
//---------------IR Sensor-----------------------------------------
int SensorAnalog = A1; // Das Sensormodul wird mit dem analogen Ausgang an Pin A1 des Arduino angeschlossen
int Wert1 = 0; // Erstellen einer Variablen mit dem Namen „Wert1“, unter dem die Messwerte gespeichert werden.
//---------------US Sensor-----------------------------------------
#include <NewPing.h>
#define TRIGGER_PIN 3 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 2 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 100 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
//---------------BT Modul------------------------------------------
char blueToothVal; //Werte sollen per Bluetooth gesendet werden
char lastValue; //speichert den letzten Status der LED (on/off)
int inByte = 0;
// ------------------- millis statt delay------------------------
unsigned long currentMillis;
const unsigned int wartezeit = 125; // in Millisekunden Zeit vergleichen
unsigned long previousTimeMillis = 0x0FFFFFFF; // damit sofort die Zeit verglichen wird
//---------------------millis statt delay------------------------
Serial.begin(9600); //serieller Monitor wird gestartet, Baudrate auf 9600 festgelegt
pinMode(13, OUTPUT); //PIN 13 wird als Ausgang festgelegt
// Motoren
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);}
// Motoren
unsigned int uS = sonar.ping();
float distance_cm = uS/57.0; // The constant "US_ROUNDTRIP_CM" = 57
currentMillis = millis();
if (currentMillis - previousTimeMillis >= 250 )//&& Wert1 > 30&& distance >=10)
{Serial.print("Ping: ");
Serial.print(distance_cm);
Serial.println("cm");}
Wert1 = analogRead(SensorAnalog); // Der analoge Wert an Pin A1 wird ausgelesen
if (Wert1<=100) // …wenn der Wert „Wert1“ kleiner oder gleich 50 ist…
//{digitalWrite(13,HIGH); // …geht die LED an…}
//---------------Motor1-----------------------------------------
// int i=56// bei 0 -55 nur fiepsen
motorspeed = i;
if (Serial.available() > 0) {
inByte = Serial.read();
switch (inByte) {
case '0':
digitalWrite(13, LOW); //...soll die LED nicht leuchten
case '1':
digitalWrite(13, HIGH); //...soll die LED leuchten
case '2':// Richtung Vorwärts, beide Motoren
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
//analogWrite(enA, motorspeed);
//analogWrite(enB, motorspeed);
case '3':// Richtung Rückwärts, beide Motoren
digitalWrite(in2, LOW);
digitalWrite(in1, HIGH);
digitalWrite(in4, LOW);
digitalWrite(in3, HIGH);
//analogWrite(enB, i);
//Serial.println(motorspeed);
//delay(100);
case '4':// Richtung Links
case '5':// Richtung Rechts
case '6':// STOPP
case '7':// Geschwindigkeit LOW
analogWrite(enA, 64);
analogWrite(enB, 64);
case '8':// Geschwindigkeit MEDIUM
analogWrite(enA, 128);
analogWrite(enB, 128);;
case '9':// Geschwindigkeit FAST
analogWrite(enA, 255);
analogWrite(enB, 255);
//currentMillis = millis();
//if (currentMillis - previousTimeMillis >= 1000 )//&& Wert1 > 30&& distance >=10)
// delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
//Serial.println("IR: ");
//Serial.println(Wert1); // IR Sensor Wert
//Serial.print("/");
//Serial.print(distance); // Send ping, get distance in cm and print result (0 = outside set distance range)
// Serial.print("cm");
//Serial.print (motorspeed);
//Serial.println ("/256");
// previousTimeMillis = currentMillis;
//if (i < 246) { // ab 256 Motor Stillstand da PWM zu hoch
// i = i + 10;
// // i++;
//if (Serial.available()) //wenn Daten empfangen werden...
// blueToothVal = Serial.read(); //..sollen diese ausgelesen werden
//if (blueToothVal == '1') //wenn das Bluetooth Modul eine „1“ empfängt..
// digitalWrite(13, HIGH); //...soll die LED leuchten
//else if (blueToothVal == '0') //wenn das Bluetooth Modul „0“ empfängt...
// digitalWrite(13, LOW); //..soll die LED nicht leuchten
// if (lastValue != '0') //wenn der letzte empfangene Wert keine „0“ war...
// Serial.println(F("LED is off")); //..soll auf dem seriellen Monitor „LED is off“ angezeigt werden
// lastValue = blueToothVal;
thank you for your time
