Everything was fine until I installed Adafruit sensor library from then I can't upload my codes neither new ones or old ones that worked before.I tried updating arduino still nothing.
Here's the error message:
Arduino: 1.8.11 (Windows Store 1.8.28.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 2010 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 190 bytes (9%) of dynamic memory, leaving 1858 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
It also lets me upload to another port but I also get an error:
avrdude: ser_open(): can't set com-state for "\.\COM3"
Exception in thread "Thread-32" java.util.ConcurrentModificationException
at java.util.LinkedList$ListItr.checkForComodification(LinkedList.java:966)
at java.util.LinkedList$ListItr.next(LinkedList.java:888)
at processing.app.packages.LibraryList.getByName(LibraryList.java:61)
at cc.arduino.contributions.libraries.LibrariesIndexer.addToInstalledLibraries(LibrariesIndexer.java:130)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanLibrary(LibrariesIndexer.java:229)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanInstalledLibraries(LibrariesIndexer.java:201)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:161)
at cc.arduino.contributions.libraries.LibrariesIndexer.setLibrariesFolders(LibrariesIndexer.java:120)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:677)
at processing.app.Base.onBoardOrPortChange(Base.java:1333)
at processing.app.Editor$UploadHandler.run(Editor.java:2083)
at java.lang.Thread.run(Thread.java:748)
Tried again got this:
Sketch uses 1908 bytes (5%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x26
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x26
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu.
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
