Hello!
I have an Arduino Uno.
I already uploaded many programs to the arduino but suddenly it stopped working. I didn't do anything, neither changing anything on it.
I have the 1.8.1 version but there is a new one 1.8.2 .. should i get it?
The board is choosed good, and also the ports. As I said I already used arduino but it isn't working anymore. Is the problem with the arduino board itself or with the USB cable?
Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 15052 bytes (46%) of program storage space. Maximum is 32256 bytes.
Global variables use 1124 bytes (54%) of dynamic memory, leaving 924 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Sonny\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Sonny\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Sonny\AppData\Local\Temp\arduino_build_364110/Richard_Nagy_KOP.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Sonny\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8a
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Here's the error massage.
Can somebody help me? I tried everything, but nothing is working. Also we can try teamviewer.
I really need this! Tomorrow is my school finishing exam. :(((
