Hey guys.
I'm having a hard time getting the correct byte values to show-up through ZigBee communication.
But I believe it is a problem with my code, and not a problem with ZigBee communication.
here is my very simple Xbee setup for testing:
Coordinator:
API mode.
Xbee (series2) connected to my computer through serial and using the XCTU software to monitor the "receive packets".
(no arduino)
Router:
AT mode.
Xbee (series2) connected to a (battery powered) Arduino Fio (Fio uses the ATmega328P micro).
- running the following code:
// declare global variables:
// temp variables:
int temp = 1020;
byte tempHigh = 0;
byte tempLow = 0;
// voltage variables:
int voltage = 50;
byte voltageHigh = 0;
byte voltageLow = 0;
// declare an array that will store the Byte values.
byte fioData[] = {tempHigh, tempLow, voltageHigh, voltageLow};
// send the "temp" value into the intToBytes function.
intToBytes(temp, tempHigh, tempLow);
//debuging:
Serial.print("temp: ");
Serial.println(temp);
Serial.print("high: ");
Serial.println(tempHigh);
Serial.print("low: ");
Serial.println(tempLow);
// send the "voltage" value into the intToBytes function.
intToBytes(voltage, voltageHigh, voltageLow);
//debugging:
Serial.print("voltage: ");
Serial.println(voltage);
Serial.println(voltageHigh);
Serial.println(voltageLow);
// write the array of Bytes to serial:
Serial.write(fioData, sizeof(fioData));
// wait 2 seconds:
delay(2000);
// create a function that converts an int into two bytes,
// HIGH byte and LOW byte:
void intToBytes(int unsignedIntVariable, byte &highValue, byte &lowValue)
highValue = highByte(unsignedIntVariable);
lowValue = lowByte(unsignedIntVariable);
// credit:
// http://forum.arduino.cc/index.php/topic,44487.0.html
// also arduino cookbook 3.14
The GOAL:
- take a 10-bit analog reading value (0-1023) "int", and convert that into high and low "bytes".
- pass those "bytes" through Xbee's.
Why?:
just another way of sending data through xbees.
- by sending an array of bytes through the xbee's and then re-assembling those bytes into ints on the other end, I will avoid having to read HEX values (xbee's communicate w/ HEX, but I don't want to be reading HEX in my code). Hence sending an array of bytes.
The GOOD:
Xbees seem to be configured correctly:
- packets come in every 2 seconds as desired.
The global variables seem to be updating properly:
- un-commenting the debugging part of the code, and just running the Fio connected to my computer (w/o Xbee): While monitoring the serial it seems the 4 global variables that need to be changed: tempHigh, tempLow, voltageHigh, voltageLow are all updated properly.
The PROBLEM:
According to the Coordinator (reading the receive-packets through the XCTU), my "payload" (the data I am interested in sending) is only registering as whatever value I declared in the "global variables" section of my code (zero's in this case). And since those global variables seem to be updated properly when de-bugging, I am thinking there is an issue with sending bytes. - (Serial.write) - I can't seem to figure out what the issue is though. Any ideas?
Thanks
