The title is pretty self-explanatory, I've written code to take pressure and temperature data from a bmp280 pressure sensor, however with the code I've written, the serial monitor doesn't show either initialisation succeeding or failing, and it doesn't create a file either, I can't see a problem. Here is the code :
please edit your post, select the code part and press the </> icon in the tool bar to mark it as code. It's unreadable as it stands. (also make sure you indented the code in the IDE before copying, that's done by pressing ctrlT on a PC or cmdT on a Mac)
Serial.println(F("BMP280 test"));
if (!bmp.begin()) {
Serial.println(F("BMP280 not found"));
while (1) delay(10);
while (!Serial) {
To this (otherwise you may not see any useful serial messages):
while (!Serial); //wait for serial connection to be established
if (!bmp.begin()) {
Two items here #1 you need to decide when you will close the file. For example at the end of the loop. (There are debates on how often and when to close a file)
myFile.println(" *C");
myFile.close();
#2 You need to change the following line since the default mode is Read mode. myFile = SD.open("test.txt");
Since your in a loop you will want to append the file instead of overwriting it
myFile = SD.open("test.txt", FILE_WRITE);
[note some libraries require FILE_APPEND instead of FILE_WRITE]
With those two changes, you will at least have a file show up hopefully.
Which SD card adapter are you using? There is a problem with a large number of these adapters, particularly with the design labeled "Catalex", where the MISO line from the SD card is not released properly. This interferes with the use of SPI for any other device, which may be causing the BME280 library to lock up since you never see any of the Serial output after the initial "BME280 test" message.
OK so on that advice I've changed that part of the code so it now looks like this:
while (!Serial);
if (!bmp.begin()) {
pinMode (10, OUTPUT);
if (SD.begin(10)) {
Serial.println("SD is go");
Serial.println("SD is a no-go");
return;
if (myFile) {
Serial.println("File is go");
Serial.println("File has Failed");
myFile.close();
I have now closed the file at the end of the setup and the loop, however I'm still not getting anything
