problems writing output to file
Hello.
I try to write data what i receive over Serial1 to a file. The file is being created but
when i write with myFile.write or myFile.print it is always empty. When i enable
Serial1.write i see output. In this case it is tekst but the goal is to send a bmp file.
how can i write the binary what is send over Serial1 to a file ?
Regards,
Johan
#include <UTFT.h>
#include <Time.h>
#include <Timer.h>
#include <tinyFAT.h>
#include "OneWire.h"
#include "DallasTemperature.h"
#include <UTFT_SdRaw.h>
#include <SdFat.h>
#define SD_CHIP_SELECT  53  // SD chip select pin
#define SSID        "wlan";
#define PASS        "XXXXX" // My luggage has pthe same combination!
#define DEST_HOST   "bla.pm";
#define DEST_IP     "IP";
#define TIMEOUT     5000 // mS
#define CONTINUE    false
#define HALT        true
#define PORT        "80"
//Display
UTFT  myGLCD(CTE70, 38, 39, 40, 41);
UTFT_SdRaw myFiles(&myGLCD);
char fileName[] = "2468.txt";
// file system object
SdFat sd;
SdFile myFile;
// #define ECHO_COMMANDS // Un-comment to echo AT+ commands to serial monitor
// Print error message and loop stop.
void errorHalt(String msg)
  Serial.println(msg);
  Serial.println("HALT");
  while(true){};
// Read characters from WiFi module and echo to serial until keyword occurs or timeout.
boolean echoFind(String keyword)
  byte current_char   = 0;
  byte keyword_length = keyword.length();
  // Fail if the target string has not been sent by deadline.
  long deadline = millis() + TIMEOUT;
  while(millis() < deadline)
    if (Serial1.available())
      char ch = Serial1.read();
      Serial.write(ch);
      if (ch == keyword[current_char])
        if (++current_char == keyword_length)
          return true;
  return false;  // Timed out
// Read and echo all available module output.
// (Used when we're indifferent to "OK" vs. "no change" responses or to get around firmware bugs.)
void echoFlush()
  {while(Serial1.available()) Serial.write(Serial1.read());}
// Echo module output until 3 newlines encountered.
// (Used when we're indifferent to "OK" vs. "no change" responses.)
void echoSkip()
  echoFind("\n");        // Search for nl at end of command echo
  echoFind("\n");        // Search for 2nd nl at end of response.
  echoFind("\n");        // Search for 3rd nl at end of blank line.
// Send a command to the module and wait for acknowledgement string
// (or flush module output if no ack specified).
// Echoes all data received to the serial monitor.
boolean echoCommand(String cmd, String ack, boolean halt_on_fail)
  Serial1.println(cmd);
  #ifdef ECHO_COMMANDS
    Serial.print("--"); Serial.println(cmd);
  #endif
  // If no ack response specified, skip all available module output.
  if (ack == "")
    echoSkip();
    // Otherwise wait for ack.
    if (!echoFind(ack))          // timed out waiting for ack string
      if (halt_on_fail)
        errorHalt(cmd+" failed");// Critical failure halt.
        return false;            // Let the caller handle it.
  return true;                   // ack blank or ack found
// Connect to the specified wireless network.
boolean connectWiFi()
  String cmd = "AT+CWJAP=\""; cmd += SSID; cmd += "\",\""; cmd += PASS; cmd += "\"";
  if (echoCommand(cmd, "OK", CONTINUE)) // Join Access Point
    Serial.println("Connected to WiFi.");
    return true;
    Serial.println("Connection to WiFi failed.");
    return false;
// ******** SETUP ********
  Serial.begin(115200);         // Communication with PC monitor via USB
  Serial1.begin(115200);        // Communication with ESP8266 via 5V/3.3V level shifter
  Serial1.setTimeout(TIMEOUT);
  Serial.println("ESP8266 Demo");
  delay(5000);
  Serial.println(F("Initialising SD card..."));
  bool mysd = 0;
  // see if the card is present and can be initialized:
  while (!mysd)
    if (!sd.begin(SD_CHIP_SELECT, SPI_FULL_SPEED)) {
      Serial.println(F("Card failed, or not present"));
      Serial.println(F("Retrying...."));
      mysd = 1;
      Serial.println(F("Card initialised."));
  //Initialze display
  myGLCD.InitLCD(PORTRAIT);
  myGLCD.clrScr();
  myGLCD.setColor(255, 255, 255);
  delay(5000);
  echoCommand("AT+RST", "ready", HALT);    // Reset & test if the module is ready
  Serial.println("Module is ready.");
  echoCommand("AT+GMR", "OK", CONTINUE);   // Retrieves the firmware ID (version number) of the module.
  echoCommand("AT+CWMODE=1", "", HALT);    // Station mode
  echoCommand("AT+CIPMUX=1", "", HALT);    // Allow multiple connections (we'll only use the first).
  //connect to the wifi
  boolean connection_established = false;
  for(int i=0;i<5;i++)
    if(connectWiFi())
      connection_established = true;
  if (!connection_established) errorHalt("Connection failed");
  delay(5000);
  echoCommand("AT+CIFSR", "", HALT);         // Echo IP address. (Firmware bug - should return "OK".)
  // Establish TCP connection
  delay(5000);
  String cmd = "AT+CIPSTART=0,\"TCP\",\""; cmd += DEST_IP; cmd += "\",80";
  if (!echoCommand(cmd, "OK", CONTINUE)) return;
  // Get connection status
  if (!echoCommand("AT+CIPSTATUS", "OK", CONTINUE)) return;
  delay(2000);
  // Build HTTP request.
  cmd = "GET / HTTP/1.1\r\nHost: "; cmd += DEST_HOST; cmd += ":80\r\n\r\n";
  // Ready the module to receive raw data
  if (!echoCommand("AT+CIPSEND=0,"+String(cmd.length()), ">", CONTINUE))
    echoCommand("AT+CIPCLOSE", "", CONTINUE);
    Serial.println("Connection timeout.");
    return;
  // Send the raw HTTP request
  echoCommand(cmd, "OK", CONTINUE);  // GET
  //Open File
  myFile.open(fileName, O_RDWR | O_CREAT | O_AT_END);
  // Loop forever echoing data received from destination server.
  while(true)
    while (Serial1.available()){
      //Serial.write(Serial1.read());
      myFile.write(Serial1.read());
      delay(25);
      myFile.close();
  errorHalt("ONCE ONLY");
