Problens with arduino size
Hi everyone,
I've been working on a project using an ESP32 to monitor air quality and environmental conditions with sensors like PMS7003 and DHT22. The ESP32 is supposed to connect to WiFi, serve a web page where I can view the sensor data, and also provide a downloadable CSV file with logged data. However, I'm having trouble getting it to stay on. The ESP32 turns on, connects to the internet, and then suddenly reboots.
The issue seems to happen shortly after the WiFi connection is established, but I can't pinpoint why. I've checked my code for any obvious errors, and everything seems to be in order. The WiFi credentials are correct, and the code compiles without any issues.
Here is what I've got
<#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <TimeLib.h>
#include <AirGradient.h>
#include <DHT.h>
#ifdef ESP832
AirGradient ag = AirGradient(DIY_BASIC);
#else
AirGradient ag = AirGradient(ONE_INDOOR);
// AirGradient ag = AirGradient(OPEN_AIR_OUTDOOR);
#endif
#define DHTPIN 27
#define DHTTYPE DHT22
void failedHandler(String msg);
const char* ssid = "Meter 1";
const char* password = "12345671";
AsyncWebServer server(80);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Sensor Readings</title>
    <style>
        table {
            border-collapse: collapse;
            width: 100%;
        th, td {
            border: 1px solid #dddddd;
            text-align: left;
            padding: 8px;
        th {
            background-color: #f2f2f2;
    </style>
</head>
<body>
<h2>  </h2>
<table id="sensorTable">
    <tbody>
        <!-- Table rows will be inserted here -->
    </tbody>
</table>
<!-- Current sensor values -->
<h3>Device Readings</h3>
<p id="currentValues">Loading...</p>
<!-- Button to download values -->
<button id="downloadButton">Download Values</button>
<script>
    var data = [];
    // Function to update the table with sensor values and current time
    function updateSensors() {
        var tableBody = document.getElementById("sensorTable").getElementsByTagName('tbody')[0];
        tableBody.innerHTML = "";
        data.forEach(function(rowData) {
            var row = tableBody.insertRow(-1);
            rowData.forEach(function(cellData) {
                var cell = row.insertCell();
                cell.textContent = cellData;
    // Function to display the current sensor values
    function displayCurrentValues(values) {
        var currentValueElement = document.getElementById("currentValues");
        currentValueElement.innerHTML = "PM1  (µg/m3): " + values[0] + "<br>" +
                                         "PM2.5 (µg/m3): " + values[1] + "<br>" +
                                         "PM10 (µg/m3): " + values[2] + "<br>" +
                                         "Humidity (%): " + values[3] + "<br>" +
                                         "Temperature (°C): " + values[4];
    // Function to download the values into a text file
    function downloadValues() {
        fetch('/values')
            .then(response => response.text())
            .then(csvContent => {
                var encodedUri = encodeURI(csvContent);
                var link = document.createElement("a");
                link.setAttribute("href", 'data:text/csv;charset=utf-8,' + encodedUri);
                link.setAttribute("download", "sensor_values.csv");
                document.body.appendChild(link);
                link.click();
            .catch(error => console.error('Error downloading the values:', error));
    // Click event on the download button
    document.getElementById("downloadButton").addEventListener("click", downloadValues);
    // Periodically update data
    setInterval(function() {
        fetch('/values')
            .then(responseData => {
                data = JSON.parse(responseData);
                updateSensors();
            .catch(error => console.error('Error fetching sensor values:', error));
        // Fetch and display current sensor values
        fetch('/current-values')
            .then(response => response.json())
            .then(currentValues => displayCurrentValues(currentValues))
            .catch(error => console.error('Error fetching current sensor values:', error));
    }, 5000);
</script>
</body>
</html>
)rawliteral";
struct SensorData {
    std::vector<int> values;
std::vector<SensorData> sensorDataList = {{}, {}, {}, {}, {}}; // Each entry corresponds to a sensor
// Sensor values definition
DHT dht(DHTPIN, DHTTYPE);
String getTime(int i) {
    return String(hour()) + ":" + String(minute()) + ":" + String(second());
int sensor1 = ag.pms7003.getPm01Ae();
int sensor2 = ag.pms7003.getPm25Ae();
int sensor3 = ag.pms7003.getPm10Ae();
int sensor4 = dht.readHumidity();
int sensor5 = dht.readTemperature();
    dht.begin();
#ifdef ESP832
    if (ag.pms7003.begin(&Serial) == false) {
        failedHandler("Init PMS7003 failed ONE");
#else
    if (ag.getBoardType() == OPEN_AIR_OUTDOOR) {
        if (ag.pms7003t_1.begin(Serial) == false) {
            failedHandler("Init PMS7003T failed TWO");
        if (ag.pms7003.begin(Serial) == false) {
            failedHandler("Init PMS7003T failed THREE");
#endif
    WiFi.begin(ssid, password);
        Serial.println("connecting...");
    server.begin();
    setenv("TZ", "GMT-3", 1); // Set time zone to GMT-3
    configTime(0, 0, "pool.ntp.org");
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
        request->send_P(200, "text/html", index_html);
    server.on("/values", HTTP_GET, [](AsyncWebServerRequest *request) {
      String csvContent = "Date/Time,PM 1,PM 2.5,PM 10,Humidity,Temperature\n";
        for (size_t i = 0; i < sensorDataList[0].values.size(); i++) {
          csvContent += getTime(i) + ",";  // Using getTime() instead of setTime()
           for (size_t j = 0; j < sensorDataList.size(); j++) {
            csvContent += String(sensorDataList[j].values[i]) + ",";
        csvContent += "\n";
    request->send(200, "text/csv", csvContent);
    server.on("/current-values", HTTP_GET, [](AsyncWebServerRequest *request) {
        String currentValues = "[" + String(ag.pms7003.getPm01Ae()) + "," + String(ag.pms7003.getPm25Ae()) + "," +
                                String(ag.pms7003.getPm10Ae()) + "," + String(dht.readHumidity()) + "," +
                                String(dht.readTemperature()) + "]";
        request->send(200, "application/json", currentValues);
uint32_t lastRead = 0;
    int PM2;
    bool readResult = false;
    uint32_t ms = (uint32_t)(millis() - lastRead);
    if (ms >= 5000) {
        lastRead = millis();
#ifdef ESP32
        if (ag.pms7003.isFailed() == false) {
            PM2 = ag.pms7003.getPm25Ae();
            Serial.printf("PM2.5 in µg/m3: %d\r\n", PM2);
            Serial.printf("PM2.5 in US AQI: %d\r\n",
                          ag.pms7003.convertPm25ToUsAqi(PM2));
            Serial.println("PMS sensor failed");
#else
            if (ag.pms7003t_1.isFailed() == false) {
                PM2 = ag.pms7003t_1.getPm25Ae();
                readResult = true;
                readResult = true;
        if (readResult) {
                Serial.printf("PM2.5 in US AQI: %d\r\n", ag.pms7003t_1.convertPm25ToUsAqi(PM2));
                Serial.printf("PM2.5 in US AQI: %d\r\n", ag.pms7003.convertPm25ToUsAqi(PM2));
#endif
    // Add new values to the sensor data list
    sensorDataList[0].values.push_back(ag.pms7003.getPm01Ae());
    sensorDataList[1].values.push_back(ag.pms7003.getPm25Ae());
    sensorDataList[2].values.push_back(ag.pms7003.getPm10Ae());
    sensorDataList[3].values.push_back(dht.readHumidity());
    sensorDataList[4].values.push_back(dht.readTemperature());
void failedHandler(String msg) {
    Serial.println(msg);
    delay(10000);
Before I try to read your code and figure out what you want please spend the time to read the forum guidelines and post your code using code tags. Since I cannot see what you have also post links to technical information on the hardware items and your preliminary schematic be sure to show all power, ground and power sources. Useful links - check here for reference posts / tutorials Frizzing diagrams are not considered schematics here.
Is the above line really correct?
Please edit your post, select all code and click the <CODE/> button and next save your post. This will make the code easier to read, easier to copy and the forum software will display it correctly. See How to get the best out of this forum
Here is what ChatGPT has to say about your issue!
It sounds like your ESP32 might be experiencing a watchdog timer reset or a power issue. Here are a few things you can check and try to stabilize your ESP32:
1. Watchdog Timer
  • The ESP32 has a watchdog timer that resets the device if certain tasks take too long to complete. If your code has any blocking operations (like long delays or loops), this could trigger a reset.
  • Solution: Try adding delay(0); or yield(); in places where your code might be spending a lot of time.
2. Power Supply
  • The ESP32 can draw quite a bit of current, especially when WiFi is active. If your power supply is not stable, it could cause the ESP32 to reboot.
  • Solution: Ensure that your power supply can provide at least 500mA to the ESP32. If you're using a USB port to power the ESP32, make sure it's a high-quality, high-current USB port.
3. WiFi Connection Issues
  • Sometimes, the ESP32 can enter a reboot loop if it struggles to connect to a WiFi network due to weak signal strength or incorrect credentials.
  • Solution: Double-check your WiFi credentials and try moving closer to your router to improve the signal strength.
4. Check for Memory Issues
  • If your code is using too much memory (especially heap memory), the ESP32 could reboot due to memory allocation failures.
  • Solution: Monitor memory usage using ESP.getFreeHeap(); to ensure you have sufficient memory.
5. Try a Basic WiFi Sketch
  • To isolate the issue, try running a basic WiFi connection sketch without the additional sensors and server setup. This can help determine if the problem is with the WiFi connection itself or with the additional code.
Why do you have that ?
What error message do you get upon reboot?
PS: I added the code tags for you this time as I’ve seen you attempted to add some markers but failed to mark it as code. Please read the best practices
Hi! Welcome to the forum.
I don´t know what you mean by "arduino size" in the title of this topic, since the content has nothing to do with size. But I suspect that the rebooting behaviour may be caused by lack of power and voltage mismatch.
DHT22 is ok, it can operate from 3.3V and power consumption is low, but the PMS7003 is a 5V sensor and it can draw 100mA.
As you mentioned "sensors like...", should we expect there are other sensors you are not describing?
It would be interesting to see how your setup is powered and how's everything connected (schematics).
Hi, @hades_180801
What are you using as a power supply?
Do you have a DMM? (Digital MultiMeter)
Thanks... Tom... :smiley: :+1: :coffee: :australia:
ChatGPT is on to something here. In my experience, issue #1 is the most common reason for random ESP32 reboots.
