Hi there,
I need to run a script file in my linux side through my arduino sketch code.
The file is located in /arduino/ping.sh and it runs through terminal by "/arduino/ping.sh" and works.
But using my sketch it doesn't. Its like I cannot run the script at all.
Please check my code. I am a rookie in linux so I dont know much about it.
Running process using Process class.
This sketch demonstrate how to run linux processes
using an Arduino Yún.
created 5 Jun 2013
by Cristian Maglie
This example code is in the public domain.
http://arduino.cc/en/Tutorial/Process
#include <Process.h>
// Initialize Bridge
Bridge.begin();
// Initialize Serial
// Wait until a Serial Monitor is connected.
while (!Serial);
// run various example processes
runCpuInfo();
// Do nothing here.
void runCpuInfo() {
// Launch "cat /proc/cpuinfo" command (shows info on Atheros CPU)
// cat is a command line utility that shows the content of a file
Process p; // Create a process and call it "p"
p.begin("/arduino/ping.sh"); // Process that launch the "cat" command
//p.addParameter("/arduino/ping.sh"); // Add the cpuifo file path as parameter to cut
p.run(); // Run the process and wait for its termination
// Print command output on the Serial.
// A process output can be read with the stream methods
while (p.available() > 0) {
char c = p.read();
Serial.print(c);
// Ensure the last bit of data is sent.
Serial.flush();
