Hi
I have connected up an HX711 and load cell to my Arduino uno and have it working, however I would like to send commands to the Arduino from my PC to invoke the tare and other functions as needed.
So my question is how do I recieve the command and then use it to invoke the functions which will also need parameters passing to some?
The Arduino Uno creates a (virtual) serial port via the usb. That build-in serial monitor of the Arduino IDE can be used, but also any other serial terminal program, like this one : http://qst.sourceforge.net/
It is even possible to send messages from the command line in Windows.
You need to think about how to send data, the "protocol". Just a single line with number and commas or with a special start byte, perhaps a checksum, readable text or binary, and so on.
If you have an Uno and are using the USB connection to communicate with a PC you will need to communicate with the Bluetooth device using SoftwareSerial - but you may already be doing that.
Hi Peter_n, I think I didn't communicate my issue very well! Sorry.
I can receive in a windows application the text being sent via serial.print() function and I can send text from windows to the Arduino. What I can't see is how I write an event handler for the Arduino to read the data/ serial text and use it to call the hx711 functions.
Hi Robin2, I don't have bluetooth (yet ) it's serial over usb...
To read an incoming line of text, it can be read into a buffer, or use for example http://arduino.cc/en/Serial/ReadBytesUntil
Some use a sscanf() on that line, or solve the commands with normal code.
Thanks Peter,
It's understanding the coding approach in my new Arduino, I'm writing a c# windows application to talk to it, so I'm in control of both ends.
I think the links you have given me will help me design what I need.
You need to capture the data character string and then do something with the captured data. The below shows a simple capture of sent characters into a String variable, which is then converted to a number for use with servo control.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
myservo.write(n);
readString="";
I_Need_Help2:
I probably should also have made it clear that the examples in serial input basics apply to any serial input - not just Bluetooth. They were all developed using serial over USB.
