Hi
I am trying to create a code that recieves data from a joystick connected to arduino using serial and move a red circle in the screen in the x direction only. However, the circle either does not move or a nullpointerexception or numberformatexception appears.
Here is the arduino code :
int jxPin = 0; // the analog pin for the x data
int x;
x = map(analogRead(jxPin),0,1023,50,750);
Serial.println(x);
delay(100);
processing code :
import processing.serial.*;
Serial myPort;
int x;
int y = 401;
String val;
String xchar;
int l = 100;
int w = 100;
size(800,800);
String portName = Serial.list()[0];
myPort = new Serial(this, portName, 9600);
void draw() {
if (myPort.available() > 0) {
xchar = myPort.readStringUntil('\n');
if (xchar != null) {
x = Integer.parseInt(xchar); // Here I always get the NumberFormatException
background(x,y,255);
fill(255,0,0);
ellipse(x,y,l,w);
Processing code
Serial myPort;
int x;
int y = 401;
String inLine;
int l = 100;
int w = 100;
size(800,800);
myPort.bufferUntil('\n');
void draw() {
fill(255,0,0);
ellipse(x,y,l,w);
void serialEvent(Serial myPort) {
inLine = myPort.readString();
inLine = inLine.substring(0, inLine.length()-2);
x = Integer.parseInt(inLine);
Thank you it works !
Could you please explain it briefly? I am interested on what was the issue before.
Use proper event handling and setup (bufferUntil / serialEvent), then parse the received line.
Serial handling is different in Processing, where draw runs at a predetermind rate
and not as fast as possible like loop on the Arduino.
And your "if something is available read its int value" is never a good strategy to read multi-byte values.
With the baud rate you use (why 9600?) you will get one character each millisecond,
and see all of them one at a time. '7' ...... '5' ...... '0' ...... CR ..... LF
Maybe the CR and LF chars throw the conversion exception.
