Hi All,
I'm about to start a new project and would like a quick ok or other wise on the feasibility of my idea.
I want to use Processing and Minim with some pre recorded sound - straightforward I know but I also want to use Arduino (pressure sensitive pads, sonar or IR sensors) not yet decided which is best for the purpose.
The idea is that as the spectator walks past a wall mounted object the sound is generated, if they move on the sound stops. There will be three of these in a row approx 1m apart and I want to have the first one go off before the second one comes on and so on....
Has any one any experience of this and if so I would appreciate your comments code tips and any pitfalls.
The second part will involve the participant interacting with objects in a room using the same technology.
First thing to consider is what happens when your display attracts attention, and two people come to see it. One moves on, while the other stays. What will you display do?
Hi I have already considered this and it doesn't matter if one or all three sound sources are playing at the same time, any other thoughts appreciated.
Forget about there being 3 of the things. If the idea is that the display makes noise when a person approaches, and gets quiet when the person leaves, the experience is not the same if there is another person approaching while one person is stopped.
If you define what you want to happen in this situation, the implementation of the whole project is trivial. It is defining what to do when there is more than one person at/near/approaching/leaving an exhibit at one time that is the difficult part.
Sure I understand your point, thanks. Do you have any advice on which sensor is best to use and how to set it up? I have never tried to do anything like this before but have seen similar type installations in galleries. i am still a newbie to both Arduino and Processing.
