Processing sketch working great, which i can play video from hdd and I am trying to trigger video or Processing sketch from with PIR motion sensor. I also tested motion sensor with Arduino led pins, it’s flashing when PIR sensor detect motion.
How can I connect this two sketch each other and i can play any video file with PIR motion sensor in Processing.
Thank you!
int ledPin = 13; // choose the pin for the LED
int inputPin = 3; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH) {
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
Processing
import processing.video.*;
import processing.serial.Serial;
static final int PORT_INDEX = 0, BAUDS = 9600;
String myString;
Movie video;
size(640,480);
video = new Movie(this,"render.mp4");
video.loop();
//noLoop();
final String[] ports = Serial.list();
printArray(ports);
new Serial(this, ports[PORT_INDEX], BAUDS).bufferUntil(ENTER);
void draw() {
background(0);
image(video,0,0);
println(myString);
void serialEvent(final Serial s) {
myString = s.readString().trim();
redraw = true;
if (myString.equals("Motion detected!")) {
video.stop();
void movieEvent(Movie video) {
video.read();
