Hello, I am a student that have found a problem when I try to verify a program. I am new in "ardunio world" but i asked my university teacher and he didn´t know also what the problem is. I just installed alright the IDE (I know that because i did exactly the same in my other computer and it works fine) but in my laptop it doesn´t work. I post the error here to see if anyone knows what the problem is or if you can help me know how can i solve it. Thanks a lot, any help is apreciated.
Hola, soy un estudiante nuevo en el mundo de arduino. He tenido un problema cuando pulso "verificar" para compilar el programa. He preguntado a mi profesor de la universidad y el tampoco sabía que puede ser. He realizado la instalación correctamente (Lo sé porque en mi otro ordenador funciona todo perfectamente) pero en el portatil no funciona. Adjunto el error por si alguien me puede decir cual es el problema o cómo se resuelve. Muchas gracias cualquier ayuda se agradece.
File > Preferences > Show verbose output during: > compilation (check) > OK
Sketch > Compile/Verify
After the compilation fails copy ALL the text from the black console window (you will probably need to scroll up to see the whole thing) and then paste it here using code tags. If it's longer than the forum will allow then attach it as a .txt file.
