void keyPressed() {
if(key == 'r')
item.startRecording();
if(key == 's')
item.stopRecording();
Here is processing code for start and finish sound recording. How me do it with arduino ?
void keyPressed() {
if(key == 'r')
if(key == 's')
Well the plain old Arduino has no keypad, so you need to either add one or read input from a serial port. To do the later, you need to use the Serial library like this:
int incomingByte = 0; // for incoming serial data
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, DEC);
