Processing + Arduino SECONDARY WINDOW
I am creating a user interface for a lighting control system and I am needing to add a secondary window. I am also trying to display the sensor readings from the serial port of the arduino app.
PROCESSING CODE:
import controlP5.*; //import ControlPS library
ControlP5 cp5; //create ControlPS object
PFont font;
void setup(){
size(400,500); //window size, (width, height)
//adding buttons
cp5 = new ControlP5(this);
font = createFont(“calibri light”, 12); //fonts for buttons and title
cp5.addButton(“Room 1”)
.setPosition(60, 50) //x and y coordinates of upper left corner of button
.setSize(125, 100) //(width, height)
.setFont (font)
cp5.addButton(“Room 2”)
.setPosition(225, 50)
.setSize(125, 100)
.setFont (font)
cp5.addButton(“Room 3”)
.setPosition(60, 160)
.setSize(125, 100)
.setFont (font)
cp5.addButton(“All Rooms”)
.setPosition(225, 160)
.setSize(125, 100)
.setFont (font)
cp5.addButton(“Errors”)
.setPosition(60, 270)
.setSize(125, 100)
.setFont (font)
cp5.addButton(“Alarms”)
.setPosition(225, 270)
.setSize(125, 100)
.setFont (font)
cp5.addButton("—")
.setPosition(60, 380)
.setSize(125, 100)
.setFont (font)
void draw(){
background(0, 0, 0); //background color of window
//text
fill(0, 255, 0); // (r, g, b) or (0 to 255)
text(“CONTROL CENTER”, 150, 30);
This is my control center which displays the buttons for each room. I am wanting to click on room 1, 2, and 3 separately and show a secondary window that will consist of a manual on/off button as well as the sensor readings from my arduino serial port. Please let me know if I am able to add secondary windows in the processing app, or how would I adjust my code to display the secondary window?
ARDUINO SENSOR CODE:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include “Adafruit_TSL2591.h”
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591);
//Configures the gain and integration time for the TSL2591
void configureSensor(void)
tsl.setGain(TSL2591_GAIN_MED);
tsl.setTiming(TSL2591_INTEGRATIONTIME_300MS);
Serial.println(F("------------------------------------"));
Serial.print (F(“Gain: “));
tsl2591Gain_t gain = tsl.getGain();
switch(gain)
case TSL2591_GAIN_LOW:
Serial.println(F(“1x (Low)”));
case TSL2591_GAIN_MED:
Serial.println(F(“25x (Medium)”));
case TSL2591_GAIN_HIGH:
Serial.println(F(“428x (High)”));
case TSL2591_GAIN_MAX:
Serial.println(F(“9876x (Max)”));
Serial.print (F(“Timing: “));
Serial.print((tsl.getTiming() + 1) * 100, DEC);
Serial.println(F(” ms”));
Serial.println(F(”------------------------------------”));
void setup(void)
Serial.println(F(“Starting Adafruit TSL2591…”));
if (tsl.begin())
Serial.println(F(“Found a TSL2591 sensor”));
Serial.println(F(“No sensor found …”));
while (1);
configureSensor();
// The first “flag” for checking the Lux levels. If the Lux level is less than 500 then luxCheck will be 0.
// This is the yellow light
int luxCheck;
// Reads IR and full spectrum then converts to Lux and checks for less than 500 Lux value
void advancedRead(void)
sensors_event_t event;
tsl.getEvent(&event);
uint32_t lum = tsl.getFullLuminosity();
uint16_t ir, full;
ir = lum >> 16;
full = lum & 0xFFFF;
if ((event.light < 500))
luxCheck = 0;
Serial.println(F(“WARNING: LUX NOT WITHIN DESIRED RANGE!”));
Serial.print(F(“Lux: “)); Serial.println(tsl.calculateLux(full, ir), 2);
luxCheck = 1;
// Arduino loop function
void loop(void)
advancedRead();
delay(2000);
(deleted)
