processing+arduino+servo without firmata
Hi everybody
I have bought an dagu rover 5 and some micro servo's, and have been playing around with them since.
i can now control the motors from my iphone, and the servo's from my iphone, but only separated (so only the motors or only a servo).
I already tried a lot myself but could not find anything to make it work.
if somebody could help me out i would be very happy.
i used these codes for that.
this one is from projectallusion.com
the arduino code (this controls the motors)
//-----------Start Arduino code ---------------
// Test program for SparkFun Ardumoto board
// Copyright (c) 2009 mechomaniac.com
// To use, connect the Arduino to a computer and send commands using a serial terminal.
// eg AR40#   motor A forwards with a speed of 40
#define PwmPinMotorA 10
#define PwmPinMotorB 11
#define DirectionPinMotorA 12
#define DirectionPinMotorB 13
#define SerialSpeed 9600
#define BufferLength 16
#define LineEnd '#'
char inputBuffer[BufferLength];
  // motor pins must be outputs
  pinMode(PwmPinMotorA, OUTPUT);
  pinMode(PwmPinMotorB, OUTPUT);
  pinMode(DirectionPinMotorA, OUTPUT);
  pinMode(DirectionPinMotorB, OUTPUT);
  Serial.begin(SerialSpeed);
// process a command string
void HandleCommand(char* input, int length)
  Serial.println(input);
  if (length < 2) { // not a valid command
    return;
  int value = 0;
  // calculate number following command
  if (length > 2) {
    value = atoi(&input[2]);
  int* command = (int*)input;
  // check commands
  // note that the two bytes are swapped, ie 'RA' means command AR
  switch(*command) {
    case 'FA':
      // motor A forwards
      analogWrite(PwmPinMotorA, value);
      digitalWrite(DirectionPinMotorA, HIGH);
    case 'RA':
      // motor A reverse
      digitalWrite(DirectionPinMotorA, LOW);
    case 'FB':
      // motor B forwards
      analogWrite(PwmPinMotorB, value);
      digitalWrite(DirectionPinMotorB, LOW);
    case 'RB':
      // motor B reverse
      digitalWrite(DirectionPinMotorB, HIGH);
    default:
  // get a command string form the serial port
  int inputLength = 0;
  do {
    while (!Serial.available()); // wait for input
    inputBuffer[inputLength] = Serial.read(); // read it in
  } while (inputBuffer[inputLength] != LineEnd && ++inputLength < BufferLength);
  inputBuffer[inputLength] = 0; //  add null terminator
  HandleCommand(inputBuffer, inputLength);
//----------- End Arduino code ---------------
the processing code
//----------- Start Processing code ----------------
import oscP5.*;
import netP5.*;
import processing.serial.*;
Serial arduinoPort;
OscP5 oscP5;
float [] fader = new float [3];
  oscP5 = new OscP5(this,8000);
  arduinoPort = new Serial(this, Serial.list()[0], 9600);
void oscEvent(OscMessage theOscMessage) {
    String addr = theOscMessage.addrPattern();
       if(addr.indexOf("/1/fader") !=-1){
       String list[] = split(addr,'/');
     int  xfader = int(list[2].charAt(5) - 0x30);
     if(theOscMessage.get(0).floatValue() !=0){
     fader[xfader]  = theOscMessage.get(0).floatValue();
void draw() {
//---------------------------------Motor A
 if(fader[1] > 0.65){
    arduinoPort.write("AF100#");
   if(fader[1] < 0.35){
    arduinoPort.write("AR100#");
  //--------------------------------Motor B
   if(fader[2] > 0.65){
    arduinoPort.write("BF100#");
   if(fader[2] < 0.35){
    arduinoPort.write("BR100#");
  //----------------------------stop commands
     if(fader[1] < 0.65 && fader[1] > 0.35 ){
    arduinoPort.write("AF0#");
       if(fader[2] < 0.65 && fader[2] > 0.35 ){
    arduinoPort.write("BF0#");
//---------------------- End Processing Code ------------------
and I used these for the servo (i want to be able to control more then one later on)
from: GitHub - jaxzin/arduino_touchosc_servo_controller: Control a servo from an on-screen iOS dial
arduino code:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
// Range appears to be 0-171, and 600-2300 micros, 1350 midpoint
#include <Servo.h>
#define LED_PIN 13
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  digitalWrite(LED_PIN, LOW);
  //Serial.println("Enter the servo position in degrees (0 - 180), followed by a period.");
  boolean update = false;
  while(Serial.available() > 0) {
    byte temp = Serial.read();
    if(temp == '.') {
      update = true;
      pos *= 10; // shift the currently stored position
      pos += (temp - '0'); // Add the new digit;
  if(update && pos >= 0 && pos <= 180) {
    int temp = map(pos, 0, 180, 550, 2300); // Map degrees (0-180) to Futaba servo microseconds...
    myservo.writeMicroseconds(temp);
    //Serial.print("Moving to position ");
    //Serial.println(pos, DEC);
    pos = 0;
    // Blink LED as a sign of movement, twice over a quarter-second
    //blinkLed(LED_PIN, 2, 250);
  // Warn on invalid data
  else if(update) {
    //Serial.print("Invalid position [");
    //Serial.print(pos, DEC);
    //Serial.println("]. Please enter a position between 0 and 180 degrees");
    pos = 0;
void blinkLed(int pin, int times, int duration) {
  // The length of being on or off (total duration devided by the number of blinks + spaces in between)
  int pulseDuration = duration / ((times * 2) - 1);
  for(int i = 0; i < times; i++) {
    digitalWrite(pin, HIGH);
    delay(pulseDuration);
    digitalWrite(pin, LOW);
    // if its not the last blink...
    if(i != times - 1) {
processing code:
import oscP5.*;        //  Load OSC P5 library
import netP5.*;        //  Load net P5 library
import processing.serial.*;    //  Load serial library
Serial arduinoPort;        //  Set arduinoPort as serial connection
OscP5 oscP5;            //  Set oscP5 as OSC connection
int redLED = 0;        //  redLED lets us know if the LED is on or off
int [] led = new int [2];    //  Array allows us to add more toggle buttons in TouchOSC
int currentPos = 0;
int desiredPos = 0;
  size(100,100);        // Processing screen size
  noStroke();            //  We don’t want an outline or Stroke on our graphics
    oscP5 = new OscP5(this,8000);  // Start oscP5, listening for incoming messages at port 8000
   arduinoPort = new Serial(this, Serial.list()[0], 9600);    // Set arduino to 9600 baud
void oscEvent(OscMessage theOscMessage) {   //  This runs whenever there is a new OSC message
    String addr = theOscMessage.addrPattern();  //  Creates a string out of the OSC message
    if(addr.indexOf("/1/servo") !=-1){   // Filters out any toggle buttons
      //int i = int((addr.charAt(9) )) - 0x30;   // returns the ASCII number so convert into a real number by subtracting 0x30
      desiredPos  = int(theOscMessage.get(0).floatValue());     //  Puts button value into led[i]
    // Button values can be read by using led[0], led[1], led[2], etc.
void draw() {
 background(50);        // Sets the background to a dark grey, can be 0-255
  if(currentPos != desiredPos) {
    String pos = str(desiredPos);
    println("Moving to position " + pos);
    arduinoPort.write(pos);
    arduinoPort.write('.');
    currentPos = desiredPos;
  redLED = int(map(desiredPos, 0, 180, 0, 255));
  fill(redLED,0,0);            // Fill rectangle with redLED amount
  ellipse(50, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
                // 50 pixels from the top and a width of 50 and height of 50 pixels
    case 'FA':
The 'FA' is a multi-byte character constant. There is no way to send a multi-byte character constant via the serial port. So, this case will never be matched. Nor will any of the others.
I'd be happy to help you fix what you wrote. Post the Arduino sketch and the Processing sketch.
I don't have my sketches any more :~
it would have been smart'er to have saved them.
Would using firmata be much easier ? and does it also work if i want to use a bluetooth module.
I also saw your reply on this topic http://arduino.cc/forum/index.php/topic,74653.0.html this seems to work but could it be used with an iphone using touchOSC and two extra motors as in the motor code above?
BTW i am not asking if somebody could write a complete code for me, a some tips or a little guidens would be very help full
so far this is my code for using a servo from my iphone
it uses firmata (maybe it is just easier to use servo firmata)
import oscP5.; // Load OSC P5 library
import netP5.
import processing.serial.;
import cc.arduino.
OscP5 oscP5;
Arduino arduino;
int pos=0; //servo position in degrees (0..180)
int desiredPos = 0;
size(360, 200);
arduino = new Arduino(this, Arduino.list()[3], 57600); //your offset may vary
arduino.pinMode(9, 5);
  • // Button values can be read by using led[0], led[1], led[2], etc.*
    void draw()
    // read mouseX coordinate
  • int newPos = constrain(desiredPos,10,150); // update bg & servo position if mouseX changed*
  • if(newPos != pos)*
  • background(newPos);*
  • arduino.analogWrite(9, newPos);*
  • println (" newPos = " + newPos );*
  • pos=newPos; //update servo position storage variable*
Find a concrete wall. Stand about 6 inches from the wall. Spend 30 minutes pounding your head against the wall. THAT was easier than using firmata.
hhhmmm i don't think i am going to try that :stuck_out_tongue:
what would you suggest ?
Processing is able to send data to the Arduino. Make it send something like <S1,45> to move servo 1 to position 45. Make the Arduino read the data sent to it, parse the data, and do what it is it's supposed to do.
i have tried what you said so i came up with this:
but it doesn't work could you might help me ? the motors dont work and the servo doesn't work either.
also i am getting a nullpointerexception error.
could it also be possible to use something like a virtual pot meter so i can set the position as i want instead of program the arduino and then only can choose of a few positions
import cc.arduino.*;
OscP5 oscP5;
Arduino arduino;
Serial arduinoPort;
  size(360, 200);
  println("klaar voor gebruik");
  if(addr.indexOf("/1/toggle") !=-1){   // Filters out any toggle buttons
      led[i]  = int(theOscMessage.get(0).floatValue());     //  Puts button value into led[i]
void draw()
if(led[1] == 0){        //  If led button 1 if off do....
    arduinoPort.write("U");    // Sends the character “r” to Arduino
 if(led[1] == 1){        // If led button 1 is ON do...
  arduinoPort.write("P");    // Send the character “R” to Arduino
and
#include <Servo.h>
Servo myservo;
#define LineEnd '#'
int message = 0;
int redLED = 0;
  myservo.attach(9);
    return;
  int value = 0;
  if (length > 2) {
  // check commands
  switch(*command) {
    case 'FA':
      // motor A forwards
    case 'RA':
      // motor A reverse
    case 'FB':
      // motor B forwards
    case 'RB':
      // motor B reverse
    default:
  do {
if (Serial.available() > 0) { //  Check if there is a new message
      message = Serial.read();    //  Put the serial input into the message
   if (message == 'U'){  //  If a capitol R is received...
      myservo.write(160);       //  Set redLED to 255 (on)
   if (message == 'P'){  //  If a lowercase r is received...
     myservo.write(10);        //  Set redLED to 0 (off)
Arduino arduino;
This is all still Firmata crap.
just some stupid thing i forgot i am a newbie.
I have changed my coding and it now works almost as it should.
except for the servo, when i try to control it via processing it doesnt work but when i control it from the serial monitor in the arduino IDE it works but i can only send it once a command and after that it doesn´t work any more.
these ar my code:
#include <Servo.h>
Servo myservo;
#define LineEnd '#'
int message = 0;
int redLED = 0;
  myservo.attach(9);
    return;
  int value = 0;
  if (length > 2) {
  // check commands
  switch(*command) {
    case 'FA':
      // motor A forwards
    case 'RA':
      // motor A reverse
    case 'FB':
      // motor B forwards
    case 'RB':
      // motor B reverse
     case 'PU':
         myservo.write(value);
     case 'DW':
    default:
  do {
Serial arduinoPort;
OscP5 oscP5;
  arduinoPort = new Serial(this, Serial.list()[3], 9600);
  size(360, 200);
void draw()
  // -------------------------------- Motor A
    arduinoPort.write ("AF200#");
    arduinoPort.write ("AR200#");
    arduinoPort.write ("BF200#");
    arduinoPort.write ("BR200#");
   arduinoPort.write ("AF0#");
    arduinoPort.write ("BF0#");
  //--------------------------------- Servo
if(led[1] == 0){
    arduinoPort.write ("UP160#");
 if(led[1] == 1){
  arduinoPort.write ("DW10#");
    case 'FA':
Please define how you are sending these multi-byte characters to the Arduino. The Serial Monitor can not send them.
well my code works now!!! :smiley: :smiley: :smiley:
i can control a servo and two motors now from my iphone.
and i didn't change anything to the "FA" (i dont say that it can't improve my code)
